Referenced File Descriptor Fails
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am using the following code to traverse an assembly and print out the parts within it:
Public Sub TraverseAssemblySample() ' Get the active assembly. Dim fso As New FileSystemObject Dim OApp As Inventor.Application Set OApp = GetObject(, "Inventor.Application") Dim oAsmDoc As Inventor.AssemblyDocument Set oAsmDoc = OApp.ActiveDocument Debug.Print oAsmDoc.DisplayName ' Call the function that does the recursion. Call TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences, 1) End Sub Private Sub TraverseAssembly(Occurrences As ComponentOccurrences, Level As Integer) ' Iterate through all of the occurrence in this collection. This ' represents the occurrences at the top level of an assembly. Dim oOcc As ComponentOccurrence For Each oOcc In Occurrences ' Print the name of the current occurrence. Debug.Print Space(Level * 3) & oOcc.DefinitionReference.ReferencedFileDescriptor.DisplayName ' Check to see if this occurrence represents a subassembly ' and recursively call this function to traverse through it. If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then Call TraverseAssembly(oOcc.SubOccurrences, Level + 1) End If Next End Sub
The problem I have is the ReferencedFileDescriptor fails with the following message:
This error occurs here:
This is code which is from the Autodesk site but the worrying thing is this issue is completely random. It will work without issues on an assembly then another time I will get this error. Each time I get the error, it is with a different part file!! I get the error on different parts on different assemblies at different times.
Has anyone encountered this?
