Read values of prompted entries using iLogic
Hello everyone,
as the title might tell you I need help for a quite specific problem.
I got to create a drawing template and do provide prompted entries in the title block.
For my purposes I need to read their values and that is exactly my problem.
Is there anyone who has experiences with that issue and can offer a solution?
I am happy for any help or suggestions!
GosponZ
Armine,
napisi tacno sta ti treba ili koje vrijednosti trebas da upises u title blok. To je veoma jednostavno.Mozes me kontakt na email.
MechMachineMan
There are many threads about this around.
Include "GetResultText" or "SetPromptResultText" in your searches and you come across lots of documentation.
Also, inventors online help filtered to the category "developer documentation" is a great place.
http://help.autodesk.com/view/INVNTOR/2018/ENU/?query=application&cg=Developer%27s%20Documentation
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Good evening MisterZS,
thank you for your quick reply, but unfortunatly I don't speak serbian. Smiley Frustrated
GosponZ
It is not Serbian but anyway, Google translate : )
