update BOMRows during iLogic rule runtime
The attached assembly is a simplified version of my entire design. I know what is wrong but I don't see how to resolve this. My iLogic rule in the attached assembly will...
  1. Delete existing "virtual" couplers
  2. Run these functions
    RuleParametersOutput()
    InventorVb.DocumentUpdate()
  3. loops through the BOM Rows to find quantity of a specific part that already exist (the 3 starting virtual parts).
  4. Store or update those in a dictionary
  5. Add new "virtual" couplers to the assembly.
All of the above works every other time. I know the BOM is not updating after step 1. The BOMRowS.Count does not change until after my rule finishes running.
I attempted to separate this into 2 rules and call 1 rule from another but the BOM does not update until all rules are run.
MechMachineMan
Try a .rebuild. Also try re-assigning to BOM object AFTER you perform a function on the BOM, instead of using the object you had used previously.
*verbatim code below*
Class BomCouplers
	' Doc Parameters
	Shared Dim modelDoc As AssemblyDocument
	Shared Dim MainAsmFilename As String
	Shared Dim asmCompDef As AssemblyComponentDefinition
	Shared Dim UoM As UnitsOfMeasure
	Shared Dim BedCompOccS As ComponentOccurrences
	Shared Dim oBOM As BOM
	Shared Dim oBOMRowS As BOMRowsEnumerator
	Shared Dim keyVirtCoupler As String	= "VirtCoupler"
	Shared Dim CoupCounts As New Dictionary(Of String, Integer)
	Shared Dim keyVirtEndCap As String = "Virtual End Cap"
	Sub Main()
		'[ SETUP
		modelDoc = ThisDoc.Document
		MainAsmFilename = IO.Path.GetFileName(modelDoc.FullFileName)	''Assembly Filename
		''Assembly references
		UoM = modelDoc.UnitsOfMeasure
		asmCompDef = modelDoc.ComponentDefinition
		BedCompOccS = asmCompDef.Occurrences
		'[ BOM SETUP
		oBOM = asmCompDef.BOM
		If Not oBOM.StructuredViewEnabled Then
			oBOM.StructuredViewEnabled = True
			oBOM.StructuredViewFirstLevelOnly = False
			oBOM.StructuredViewDelimiter = "-"
		Dim oBOMViews As BOMViews = oBOM.BOMViews
		Dim oBOMStruct As BOMView = oBOMViews.Item("Structured")
		oBOMRowS = oBOMStruct.BOMRows
		CoupCounts.Clear()	''reset dictionary
		DeleteVirtCouplers()	'' delete all virtual pipe couplers
		CountPrefabEndCaps()
		''iterate through Coupler counts dictionary
        Dim pair As KeyValuePair(Of String, Integer)
        For Each pair In CoupCounts
            Dim size As String = pair.Key
			Dim PlainEnds As Integer = pair.Value
			'MessageBox.Show("size: " & vbTab & size & vbCrLf & "PlainEnds: " & vbTab & PlainEnds & vbCrLf & "zzzzzzzzz: " & vbTab & zzzzzzz)
			''number of plain ends divided by 2 = couplers
			Dim qty As Integer = Ceil(PlainEnds/2)
			'MessageBox.Show("size: " & vbTab & size & vbCrLf & "PlainEnd: " & vbTab & PlainEnds & vbCrLf & "qty: " & vbTab & qty)
   			VirtCoupler(qty, size)	''Create or or update
        Next
	End Sub
	Sub CountPrefabEndCaps()
		Dim PF_Size As String
		Dim PropSetPrj As PropertySet
		Dim BOM_PN As String
		For Each oBOMRow In oBOMRowS
			''query part number and quantity
			oCompDef1 = oBOMRow.ComponentDefinitions.Item(1)
			If TypeOf oCompDef1 Is VirtualComponentDefinition Then
				PropSetPrj = oCompDef1.PropertySets.Item("Design Tracking Properties")
			Else
				''line below will return the assembly file name for Virtual Components
				PropSetPrj = oCompDef1.Document.PropertySets.Item("Design Tracking Properties")
			BOM_PN = PropSetPrj.Item("Part Number").Value
			''query part number for size
			PF_Size = PrefabStubSize(BOM_PN)
			If PF_Size <> "" Then	''PN is a End Cap with a Prefab Stub
				Dim TotQTY As String = oBOMRow.TotalQuantity
				Dim PF_Qty As Integer = CInt(TotQTY)
				''Each prefab Stub would have a plain end
				If CoupCounts.TryGetValue(PF_Size, currentCount) Then
					''add value to existing key
					CoupCounts(PF_Size) = currentCount + PF_Qty
				Else
					''create key and store value
					CoupCounts.Add(PF_Size, PF_Qty)
		Next
	End Sub
	Function PrefabStubSize(strPN As String) As String
		Dim size As String
		Select Case strPN
			Case "SC310EPE10B", "SC310EPE10T"
				size = "10"
			Case "SC310EPE12B"
				size = "12"
			Case "SC740EPE18", "SC740EPE18B", "SC740EPE18T"
				size = "18"
			Case "SC740EPE24B", "SC740EPE24"
				size = "24"
			Case Else
				''if part number is not above then it's not a prefab stub
				size = ""
		End Select
		Return size
	End Function
	'[ VIRTUAL
	Sub DeleteVirtCouplers()
		''Deletes all Virtual Split Couplers
		For Each occ In BedCompOccS
			If iProperties.Value(occ.Name, "Summary", "Keywords") = keyVirtCoupler Then
				occ.Delete
		Next
	End Sub
	Sub VirtCoupler(qty As Integer, size As String)
		Dim identity As Matrix
		identity = ThisServer.TransientGeometry.CreateMatrix
		Dim virtOcc As ComponentOccurrence
		Dim strPN As String = Coupler_PN(size)
		Dim strDesc As String = Coupler_Desc(size)
		Dim strCompName As String = "Coupler " & size & " inch"
		''create first instance Of the virtual part
		virtOcc = BedCompOccS.AddVirtual(strCompName, identity)
		virtOcc.Name = strCompName
		''iProperties and quantity
		iProperties.Value(strCompName, "Project", "Part Number") = strPN
		iProperties.Value(strCompName, "Project", "Description") = strDesc
		iProperties.Value(strCompName, "Summary", "Keywords") = keyVirtCoupler
		iProperties.Value(strCompName, "Custom", "STAN") = "STAN"
		iProperties.Value(strCompName, "Project", "Vendor") = "ADS"
		iProperties.Value(strCompName, "Custom", "NOTE") = "NOT SHOWN"
		iProperties.Value(strCompName, "Custom", "ItemPriority") = 15.0
		ThisBOM.OverrideQuantity("Model Data", strPN, qty)
	End Sub
	'[ COUPLER
	Function Coupler_PN(size As String) As String
		Dim strPN As String
		Select Case size
			Case "4"
				strPN = "0412AA"
			Case "6"
				strPN = "0613AA"
			Case "8"
				strPN = "0813AA"
			Case "10"
				strPN = "1011AA"
				''future option "1013AA"	"10"".DWALL SNAP COUPLER.(3/BG)"
			Case "12"
				strPN = "1265AA"
			Case "15"
				strPN = "1565AA"
			Case "18"
				strPN = "1865AA"
			Case "24"
				strPN = "2465AA"
			Case "30"
				strPN = "3065AA"
			Case "36"
				strPN = "3661AA"
			Case "42"
				strPN = "4265AA"
			Case "48"
				strPN = "4865AA"
			Case "60"
				strPN = "6065AA"
			Case Else
				strPN = "??????????"
		End Select
		Return strPN
	End Function
	Function Coupler_Desc(size As String) As String
		Select Case size
			Case "4"
				Desc = "4"".SNAP COUPLER.(24/BG)"
			Case "6"
				Desc = "6"".DWALL SNAP COUPLER.(8/BG)"
			Case "8"
				Desc = "8"".DWALL SNAP COUPLER.(4/BG)"
			Case "10"
				Desc = "10"".SPLIT COUPLER.(H - 12/BG)"
			Case "12"
				Desc = "12"".SPLIT COUPLER.(200/PALLET)"
			Case "15"
				Desc = "15"".SPLIT COUPLER.(150/PALLET)"
			Case "18"
				Desc = "18"".SPLIT COUPLER.(150/PALLET)"
			Case "24"
				Desc = "24"".SPLIT COUPLER.(100/PALLET)"
			Case "30"
				Desc = "30"".SPLIT COUPLER.(50/PALLET)"
			Case "36"
				Desc = "36"".SPLIT COUPLER.(50/PALLET)"
			Case "42"
				Desc = "42"".SPLIT COUPLER.(50/PALLET)"
			Case "48"
				Desc = "48"".SPLIT COUPLER.(25/PALLET)"
			Case "60"
				Desc = "60"".SPLIT COUPLER.(25/PALLET)"
			Case Else
				PN = "??????????"
		End Select
		Return Desc
	End Function
End Class
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
@MechMachineMan Thank you very much. I didn't need the oBOM until after I deleted the VirtualCouplers anyway. No update or rebuild needed!
