Re-Create an Element
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
AFAIK most crashes of Inventor are provokated with so called Bad Bodies (issues in 3D topology that could be revealed with non-documrnted build-in utility BSCT, called by Ctrl+F7 )
The most notorious is that those bad bodies can be any where even in templates of some standard (produced by Autodesk itself) families of Content Center (ex DIN 1587 nut).
But even worse is the fact that to fix the bad body issue (except those imported) the element should be deleted and created (with all the same parameter set). Taking to account that in our Vault there are hundreds of "bad" IPTs. it is
definitely not human task to recreate elements.
I wonder is there already some add-on or macro that being run on particular elemnet recreates it with as less as possible difference from initial (desirably such that wont breake dimensions on IDW etc)?
Thanks in advance.
For the topic of Bad Bodies see also:
https://forums.autodesk.com/t5/inventor-forum/bad-body-error-edge-intended-convexity-disagrees-with-...
Please vote for Inventor-Idea Text Search within Option Names
