Print only A4 Sheets in a Drawing
CCarreiras
Mentor Mentor
Message 1 of 10
CCarreiras
Hi!
The goal:
is to print only the A4 size sheets in a multisheet drawing (Portrait and landscape).
Im using the code below to select only the A4 size sheets and print them.
Problem:
When i print, it select well the number, size and orientation for the A4 sheets in the document, but only print the content (views, border, Titleblock) of the active sheet.
i.e
If i have 4 sheets in the drawing,
Sheet 1 is not A4 and is active
Sheet 2 is A4 Portrait
Sheet3 is A4 Landscape
Sheet4 is not A4
then, it will print two paper sheets(correct): one size A4 and Portrait (from sheet2 specifications), other size A4 Landscape (from sheet 3 specifications), but both have the content of the sheet1 (active sheet)
Any help to correct this?
Thanks.
SyntaxEditor Code Snippet
'Define the drawing
Dim oDrawing As DrawingDocument
oDrawing = ThisApplication.ActiveDocument
Dim oSheet As Sheet
For Each oSheet In oDrawing.Sheets
		If oSheet.Size = kA4DrawingSheetSize And oSheet.Orientation = kPortraitPageOrientation Then
			oPrintMgr = ThisApplication.ActiveDocument.PrintManager
			'oPrintMgr.ColorMode = kPrintGrayScale
			oPrintMgr.ColorMode = kPrintColorPalette
			oPrintMgr.NumberOfCopies = 1
			oPrintMgr.ScaleMode = kPrintFullScale
			oPrintMgr.Orientation = kPortraitOrientation
			'oPrintMgr.Orientation = kLandscapeOrientation
			oPrintMgr.PaperSize = kPaperSizeA4
			oPrintMgr.PaperHeight = 210 mm
			oPrintMgr.PaperWidth = 297 mm
			oPrintMgr.SubmitPrint
		If oSheet.Size = kA4DrawingSheetSize And oSheet.Orientation = kLandscapePageOrientation Then
			'oPrintMgr.Orientation = kPortraitOrientation
			oPrintMgr.PaperHeight = 297 mm
			oPrintMgr.PaperWidth = 210 mm
Next
CCarreiras
Replies (9)
Message 2 of 10
bradeneuropeArthur
Code is a little modified.
Please use the correct declarations!!
You need to do this also with the printermanager declarations.
I assume you know how to do this now!
Dim oDrawing As Inventor.DrawingDocument
Dim oSheet As Inventor.Sheet
		If oSheet.Size =  Inventor.DrawingSheetSizeEnum.kA4DrawingSheetSize And oSheet.Orientation = Inventor.PageOrientationTypeEnum.kPortraitPageOrientation Then
		If oSheet.Size = Inventor.DrawingSheetSizeEnum.kA4DrawingSheetSize And oSheet.Orientation = Inventor.PageOrientationTypeEnum.kLandscapePageOrientation Then
Next
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 10
CCarreiras
HI!
Thank you for your reply.
With your code i got the same result.
The question isnt about size or orientation, is about to activate the proper sheet to print.
It choose the size and orientation based in the rules, but print in every paper only the content of the active sheet in the moment i push the rule.
CCarreiras
Message 4 of 10
bradeneuropeArthur
For me this works:
Vba:
Public Sub main()
Set oDrawing = ThisApplication.ActiveDocument
Dim oPrintMgr As Inventor.PrintManager
Set oPrintMgr = ThisApplication.ActiveDocument.PrintManager
'MsgBox oSheet.Orientation
            MsgBox "P"
            MsgBox "L"
            'oPrintMgr = ThisApplication.ActiveDocument.PrintManager
Next
End Sub
I Logic
Public Sub main()
            MsgBox "P"
            MsgBox "L"
Next
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 10
CCarreiras
Hi!
Are you sure it work for you? Did you test it?
For me, i had the same behavior of the original code, no changes using both of your codes.
I'm using Inventor 2019.0.1
Tested in a  Drawing with 4 sheets, conditions explained in the first post.
Ps: didnt test the vb version, only iLogic.
Thank you.
CCarreiras
Message 6 of 10
bradeneuropeArthur
The problem you have has to do with the printer selves.
you need to let recognize the printer what sheet format is printed.
the printer manager of inventor has nothing to do with that.
so landscape or portrait has to be read and set in the printer...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 10
chandra.shekar.g
Autodesk Support
Autodesk Support
@CCarreiras,
Try below iLogic code to print A4 sheets in a drawing. To print A4 sheet, it is advised to activate and print the same.
  			 ActiveSheet = ThisDrawing.Sheet(oSheet.Name)
Next
Please feel free to contact if there is any queries.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 8 of 10
bradeneuropeArthur
with the Comments of @chandra.shekar.g this will do the job:
Public Sub main()
Dim ActiveSheet As Sheet
        oSheet.Activate
            MsgBox "P"
        oSheet.Activate
            MsgBox "L"
Next
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 10
chandra.shekar.g
Autodesk Support
Autodesk Support
@bradeneuropeArthur,
As the user is familiar with iLogic functions. Intentionally, I included ActivateSheet = ThisDrawing.Sheet(oSheet.Name) function in iLogic code.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 10 of 10
CCarreiras
@chandra.shekar.g, thank you very much, activating the sheet in each step did the trick, it's working.
@bradeneuropeArthur, was not a question of orientation, that, has i told you worked good, was a question of printing the right content. Thank you anyway.
CCarreiras
