Get parameter values and set in multiple lists
tracey
tracey
‘I have two parameters in two subassemblies:
'Controlling values in sub assemblies
Values = Parameter("C1 Right Framework - Lower:1", "LowerDoor")
Values = Parameter("C1 Upper Framework - Upper Master:1", "UpperDoor")
'Based on the value in the sub assemblies, I want to find which list has the same value and set it.
'Get all four door variation lists
'("DoorLowerA", "0","AA","BB","CC","DD","EE","FF","II","JJ","KK","LL","OO","PP","QQ")
values = MultiValue.List("DoorLowerA")
'("DoorUpperB", "0","A","B","C","D","E","F","I","J","K","L","O","P")
values = MultiValue.List("DoorUpperB")
'("DoorLowerC", "0","GG","HH","MM","NN")
values = MultiValue.List("DoorLowerC")
'("DoorUpperD ", "0","G","H","M","N")
values = MultiValue.List("DoorUpperD")
 'Parameter "LowerDoor" and "UpperDoor" has a value - If it is found in any of these lists then the list with the value needs to be set to match the value or set it to 0.
 If foundVal = MultiValue.FindValue(MultiValue.List ("DoorLowerA",)) "=" Parameter("C1 Right Framework - Lower:1", "LowerDoor") AndAlso
foundVal = MultiValue.FindValue(MultiValue.List ("DoorUpperB")) "=" Parameter("C1 Upper Framework - Upper Master:1", "UpperDoor") Then
Component.IsActive("Front Panel Assembly E2E4 Both 1")= True
ElseIf foundVal = MultiValue.FindValue(MultiValue.List("DoorLowerA"))"=" Parameter("C1 Right Framework - Lower:1", "LowerDoor")AndAlso
foundVal = MultiValue.FindValue(MultiValue.List("DoorUpperB"))=” Parameter("C1 Upper Framework - Upper Master:1", "UpperDoor") Then
Component.IsActive("Front Panel Assembly E6 Both 1")= True
ElseIf foundVal = MultiValue.FindValue(MultiValue.List("DoorLowerA")) "=" Parameter("C1 Right Framework - Lower:1", "LowerDoor")AndAlso
foundVal = MultiValue.FindValue(MultiValue.List("DoorUpperB"))=” Parameter("C1 Upper Framework - Upper Master:1", "UpperDoor")Then
Component.IsActive("Front Panel Assembly E6 Upper 1")= True
ElseIf foundVal = MultiValue.FindValue(MultiValue.List("DoorLowerA")) "=” Parameter("C1 Right Framework - Lower:1", "LowerDoor")AndAlso
Component.IsActive("Front Panel Assembly E6 Lower 1")= True
'various Errors:  Argument not specified for parameter 'operatorStr' of 'Public Function FindValue(valList As System.Collections.ICollection, operatorStr As String, valA As Object, [tolerance As Double = 0.0000001]) As Object'.
 Clearly my syntax is wrong here.  I am not a good enough coder to adapt the various cycle through the lists and find type rules and make them work
Any help would be appreciated.
Tracey
dgreatice
did you missing comma?
Default :
foundVal = MultiValue.FindValue(MultiValue.List("d0"), "<=", 4.0)
 Editing:
foundVal = MultiValue.FindValue(MultiValue.List("DoorLowerA"), "=", Parameter("C1 Right Framework - Lower:1", "LowerDoor")
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
tracey
Thank you for your help.
I get this error for the below piece of code:
Error on Line 33 : Argument not specified for parameter 'operatorStr' of 'Public Function FindValue(valList As System.Collections.ICollection, operatorStr As String, valA As Object, [tolerance As Double = 0.0000001]) As Object'.
Error on Line 33 : Argument not specified for parameter 'valA' of 'Public Function FindValue(valList As System.Collections.ICollection, operatorStr As String, valA As Object, [tolerance As Double = 0.0000001]) As Object'.
Error on Line 33 : End of statement expected.
Not sure how to sort this out!
If foundVal = MultiValue.FindValue(MultiValue.List ("DoorLowerA")), "=", Parameter("C1 Right Framework - Lower:1", "LowerDoor") AndAlso
