Help with theory behind placing components in a assembly using iLogic
I have recently been tasked with creating an iLogic script and form to speed up the process of designing a ladder that has legs that attach itself to the tank. Adjusting the rungs is super easy but there has been an issue in figuring out how I should approach the legs.
I want to be able to place the legs at specific points and double check if it makes contact with a tank seam. If it does I want to have it move up or down so it doesn't.
Should I be approaching this still with iLogic or is this more of a inventor API problem.
Thanks for the help!
dgreatice
can you provide screenshot, or video how you workflow begin?
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
