pdf ilogic question
pdf ilogic question
GosponZ
Message 1 of 11
pdf ilogic question
GosponZ
For many years using iLogic to export pdf to certain folder and never ever had problem. Yesterday my college had problem run that rule always with message like somebody has file open and can't overwrite. I don't think is code. What could cause problem. His machine is brand new and first file ever made on that machine. Thanks
Replies (10)
Message 2 of 11
bradeneuropeArthur
Has you colleague the file preview on in the windows explorer, for files (preview screen)?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 11
tomislav.peran
I had the same problem with exporting the parameters to excel. I got msge that Excell file is opened and can not be overwritten.I tried different things.
1. Restarting my PC worked nicely
2. I broke the link with excell file via Tools -> Links
3. I made a new excell file with the new name and replaced the name of the excell file in code with the new one.
Not sure if this helps in your case but I wrote it just in case.
Tom
Message 4 of 11
vpeuvion
Hi, you probably have the same problem as for the pdf.
When using the preview pane display in windows explorer if a folder is open and your file is viewed it may be considered read-only and you cannot overwrite or open it for writing with software .
You can test by unchecking this option.
I hope this will help you.
Vincent.
Message 5 of 11
tomislav.peran
Hi Vincent,
Thanks a lot. I will most certainly test it!
Tom
Message 6 of 11
GosponZ
Yes, i do have same but i never ever had problem.
Message 7 of 11
GosponZ
We turn off and on. Every time same. ILogic  pdf export is no working, but export pdf is working.
Message 8 of 11
vpeuvion
Weird, the ILogic pdf export uses the manual export options.
It's not a file access problem? If you try to export to desktop for example with Ilogic, does it work?
Vincent.
Message 9 of 11
GosponZ
Last night i saved bunch pdf's with iLogic no problem at all. Like all these years. This Morning it happened to me.
File path is to the server but it should not be a problem. I saved file to c drive with no problem. I'm just confused what is going on. Is this newest windows update makes problem? Last night it is installed and reboot my laptop.
Then problem.
Message 10 of 11
vpeuvion
When you do a pdf export manually from this PC, do you do it in exactly the same location as in the Ilogic rule, on the server?
I don't think windows update has anything to do with this issue.
Vincent.
Message 11 of 11
GosponZ
Manually is no problem anywhere to export pdf. It is just wierd that stop working for iLogic. I'm using same code for many years never had problem. It is big deal now for me.
