How to delete all feature control frames in my sheet
artemijs.nille
artemijs.nille
i would like to delete all feature control frame in my sheet (see picture below)
Launching this code:
Dim oDoc As Document = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Dim oFCF As FeatureControlFrame
For Each oSheet In oDoc.Sheets
	For Each oFCF In oSheet.DrawingDimensions
			oFCF.Delete
	Next
Next
i get following message:
Unable to cast COM object of type 'System.__ComObject' to interface type 'Inventor.FeatureControlFrame'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{F3E768AB-B2BC-42B4-B95F-ED49BE550257}' failed due to the following error: Schnittstelle nicht unterstützt (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
how can get this code to work?
bradeneuropeArthur
Put a
Try
##.delete
Catch
End try
And the code between.
Arthur
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
artemijs.nille
Thank you for a reply.
I dont get an erroe message anymore, but all FCF are still there.
So the code doesnt work.
Any ideas?
bradeneuropeArthur
Will have a look!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
artemijs.nille
could you find a reason why it does not work?
Thank you in advance.
WCrihfield
Hi @artemijs.nille.  Simple mistake is causing Type mismatch.
Should be:
For Each oFCF In oSheet.FeatureControlFrames
Wesley Crihfield
(Not an Autodesk Employee)
artemijs.nille
Thank you very much it helped
