- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
The below code I had pieced together had worked flawlessly for some time with Inventor 2018.
It usually exports only the first page of a multi sheet document.
However with 2021, it exports the all sheets as a single pdf, which is not the original intent.
Can you please review & comment as to why the version change would affect the code?
'------start of iLogic-------
oPath = ThisDoc.Path
oFileName = ThisDoc.FileName(False) 'without extension
oRevNum = iProperties.Value("Project", "Revision Number")
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
'2018 PDF EXPORT
'If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
'oOptions.Value("All_Color_AS_Black") = 0
'oOptions.Value("Remove_Line_Weights") = 0
oOptions.Value("Vector_Resolution") = 400
'oOptions.Value("Sheet_Range") = 'Inventor.PrintRangeEnum.kPrintAllSheets
oOptions.Value("Custom_Begin_Sheet") = 1
oOptions.Value("Custom_End_Sheet") = 1
'End If
'get PDF target folder path
oFolder = oPath & "\PDF"
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
End If
'Set the PDF target file name
oDataMedium.FileName = oFolder & "\" & oFileName & _
" Rev" & oRevNum & " GA" & ".pdf"
On Error Goto handlePDFLock
'Publish document
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
Exit Sub
handlePDFLock:
MessageBox.Show("PDF could not be saved, most likely someone else has it open", "No PDF for you " & ThisApplication.GeneralOptions.UserName & "!")
Resume Next
'Show message box
MessageBox.Show("Drawing saved and PDF Exported to LAST EDITED document folder/PDF", "Save I-logic")
'------end of iLogic-------
