iLogic Rule to export custom number of pdf sheet
With the help of the comunity I was able to piece together a custom code that print pdf files. I have attached the code below of what  I have. My code currently spits out Page/Sheet 1 to 10. What I want to do is give the user the option to choose which sheet they want to export, instead of all of them. Eg. I want to print only page 2 to 5 or just page 1. Is there any code or example that I can add to my code that will have a pop-up window where the user inputs what sheets he wants?
I need to change the these lines to something else that will enable the option I want:
		oOptions.Value("Custom_Begin_Sheet") = 1
		oOptions.Value("Custom_End_Sheet") = 10
'iLogic rule to export PDF from Inventor Drawings
'By Fazlur Rahaman
'May 5, 2016
Imports System.Windows.Forms
'query user
'------start of iLogic-------
question = MessageBox.Show("You want to create PDF of this file?", "Question",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
'set condition based on answer
If question = vbYes Then
	' Get current location of this file
	Dim ExportPath As String = ThisDoc.Path
	' Check that this file has been saved and actually exists on disk
		If String.IsNullOrEmpty(ExportPath) Then
			MsgBox("This file has not yet been saved and doesn't exist on disk! - please save it first",64, "PDF EXPORT!")
		Return
	' Define folder browse dialog
	Dim Dialog = New FolderBrowserDialog()
	' Set options for folder browser dialog
	Dialog.SelectedPath = ExportPath
	Dialog.ShowNewFolderButton = True
	Dialog.Description = "Choose Folder for Export..."
	' Show dialog box
	If DialogResult.OK = Dialog.ShowDialog() Then
		' User clicked 'ok' on dialog box - capture the export path
		ExportPath = Dialog.SelectedPath & "\"
	Else
	' User clicked 'cancel' on dialog box - exit
	Return
	oPath = ThisDoc.Path
	oFileName = ThisDoc.FileName(False) 'without extension
	oRevNum = iProperties.Value("Project", "Revision Number")
	oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
	("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
	oDocument = ThisApplication.ActiveDocument
	oContext = ThisApplication.TransientObjects.CreateTranslationContext
	oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
	oOptions = ThisApplication.TransientObjects.CreateNameValueMap
	oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
	'Formate PDF Setting
	If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
		oOptions.Value("All_Color_AS_Black") = 1
		oOptions.Value("Remove_Line_Weights") = 1
		oOptions.Value("Vector_Resolution") = 4800
		oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
		'Number of pages to be published
	'get PDF target folder path
	oFolder = ExportPath
	If iProperties.Value("Project", "Revision Number") >= "1" Then
		'Set the PDF target file name
		oDataMedium.FileName = oFolder & "\" & oFileName & _
		" R" & oRevNum & ".pdf"
	Else
		'Set the destination file name
	Else
	Return
On Error Goto handlePDFLock
	'Publish document
	oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
	'Option to the user if they want to open the file
	question2 = MessageBox.Show("Open PDF file?", "Question",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
	If question2  = vbYes Then
		ThisDoc.Launch(oDataMedium.FileName)
Exit Sub
handlePDFLock:MessageBox.Show("PDF not created, most likely someone else has it open.", "No PDF for you " & ThisApplication.GeneralOptions.UserName & "!")
'Resume Next
Owner2229
Hi, I've made some minor spring cleaning in your code, I hope you don't mind Smiley Happy
Anyway, red highlighted is the code for Sheet Range input. You can use eighter single sheet (e.g.: 5) or sheet range (e.g. 5-7).
'By Fazlur Rahaman
'May 5, 2016
' Query user
question = MessageBox.Show("You want to create PDF of this file?", "Question", MessageBoxButtons.YesNo, MessageBoxIcon.Question)
' Set condition based on answer
If question <> vbYes Then Exit Sub
	Exit Sub
If DialogResult.OK = Dialog.ShowDialog() Then ' Show dialog box
Else
	Exit Sub ' User clicked 'cancel' on dialog box - exit
Dim SheetRange As String = InputBox("Please enter the range of sheets you want to export." & vblf & _
"You can use these input types:" & vblf & "  ' 1 ' ,  ' 1-10 ' ", "Sheet range", "1-10")
If SheetRange = vbNullString Then Exit Sub
Dim SPL As Integer = InStr(SheetRange, "-")
Dim L1 As Integer
Dim L2 As Integer
If SPL > 0 Then
	L1 = Val(Left(SheetRange, SPL))
	L2 = Val(Mid(SheetRange, SPL + 1))
Else
	L1 = Val(SheetRange)
	L2 = Val(SheetRange)
' Formate PDF Setting
If Not oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then Exit Sub
' Range of pages for publishing
oOptions.Value("Custom_Begin_Sheet") = L1
oOptions.Value("Custom_End_Sheet") = L2
ExportPath = ExportPath & "\" & ThisDoc.FileName(False)
	ExportPath = ExportPath & " R" & iProperties.Value("Project", "Revision Number")
oDataMedium.FileName = ExportPath & ".pdf"
Try
	' Publish document
	' Ask the user if he wants to open the file
Catch
End Try
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Thank you for your help. It works flawlessly. I appreciated you take your time and cleaning up my codes, Im still new to this and learning 🙂
Owner2229
You're welcomed Smiley Happy
Mike
RoyWickrama_RWEI
Nice code. I has most of the options I need to customize for my needs. Thanks a lot.
Hi
Very often in one IDW I'm inserting parts from whole machine.
Is there any way to save custom sheets ranges using iLogic? For example into one PDF file, sheets from 1-3 and from 10-15 and so on.
I will be very grateful for yours opinion.
william
Hello @Anonymous
See this thread here https://forums.autodesk.com/t5/inventor-customization/printing-selected-pages-with-ilogic-how-to-clean-the-code/td-p/9288289
Instead of specifying a range with kPrintSheetRange, you could use kPrintAllSheets and set the sheets that you dont want output to Exclude from printing.
For Example, I have a rule that outputs all sheets except ones that have a sales titleblock in them.
Dim oDrawDoc As Object = ThisApplication.ActiveDocument
Dim oSheet As Sheet
For Each oSheet In oDrawDoc.Sheets
	If oSheet.TitleBlock.Name.Contains("SALES") Then
		oSheet.ExcludeFromPrinting = True
Next
 At the end of the rule you can reset all the sheets by
	oSheet.ExcludeFromPrinting = False
Next
