Printing selected pages with Ilogic. How to clean the code?
FeelGoodGirl
Message 1 of 9
FeelGoodGirl
Hey,
I am working on a piece of code so that you can choose which pages you want to print and then print them immediately.
The code works fine. You choose the pages and print on printing and you can print the chosen pages. You need to be able to put a check mark on the sheet you want to print. Because of this there is a lot of extra code.
I was wondering if anyone knows how to clean up my code? Or maybe does someone knows another way to switch between true and false? For 3 pages it is still possible, but in the end I have a lot more pages.
Thanks in advance
Dim oDrgDoc As DrawingDocument
Dim oDrgPrintMgr As DrawingPrintManager
oDrgDoc = ThisApplication.ActiveDocument
oDrgPrintMgr = oDrgDoc.PrintManager
' Switch between true and false
If Sheet1 = True Then
		oSheet1 = False
	Else
		oSheet1 = True
If Sheet2 = True Then
		oSheet2 = False
	Else
		oSheet2 = True
If Sheet3 = True Then
		oSheet3 = False
	Else
		oSheet3 = True
' Provide the good status to the page
ThisDoc.Document.Sheets.Item("Sheet:1").ExcludeFromPrinting = oSheet1
ThisDoc.Document.Sheets.Item("Sheet:2").ExcludeFromPrinting = oSheet2
ThisDoc.Document.Sheets.Item("Sheet:3").ExcludeFromPrinting = oSheet3
'--------Printing--------
'Printer name
oDrgPrintMgr.Printer = "Microsoft Print to PDF"
oDrgPrintMgr.SetSheetRange(1,3)
'Paper size, scale and orientation
oDrgPrintMgr.ScaleMode = PrintScaleModeEnum.kPrintBestFitScale
oDrgPrintMgr.PaperSize = PaperSizeEnum.kPaperSize11x17
oDrgPrintMgr.PrintRange = PrintRangeEnum.kPrintSheetRange
oDrgPrintMgr.Orientation = PrintOrientationEnum.kLandscapeOrientation
oDrgPrintMgr.SubmitPrint()
Replies (8)
Message 2 of 9
mcgyvr
Using Case statements can help reduce "If/Then" complexity some..
Have you looked into that?
Message 3 of 9
FeelGoodGirl
I would not know how this would make the code shorter and clearer ..... 🙈
Message 4 of 9
You're wanting the value of oSheet1 to be the opposite of Sheet1 right? Try this:
oSheet1=Not(Sheet1)
This should return the opposite value and get rid of all the if-then statements. Hope this helps!
-Chancellor
Message 5 of 9
FeelGoodGirl
This was exactly what I needed. I did not know that there was a piece of code with which you could "flip" the value.
Thank you for your time!
Message 6 of 9
Curtis_Waguespack
Hi @FeelGoodGirl
Using  the suggestion of ckurre, you could use the exclude from printing function to set the selected sheets, and then use the Print Range enumerator kPrintAllSheets, so that it prints all sheets not set to be excluded, and then finally set all sheets back to be included at the end.
I hope this helps.
Curtis
oSheets = ThisDoc.Document.Sheets
'set print status based on checkboxes
oSheets.Item("Sheet:1").ExcludeFromPrinting = Not Parameter("Sheet1")
oSheets.Item("Sheet:2").ExcludeFromPrinting = Not Parameter("Sheet2")
oSheets.Item("Sheet:3").ExcludeFromPrinting = Not Parameter("Sheet3")
'Printer name
' Set to print all sheets (all sheets not set to be excluded)
oDrgPrintMgr.PrintRange = kPrintAllSheets
'set all sheets back to default ( to be printed)
For Each oSheet In oSheets
	oSheets.Item(oSheet.name).ExcludeFromPrinting = False
Next
Message 7 of 9
FeelGoodGirl
I have now succeeded in making my code smaller. However, other challenges have now emerged. For this I have started a new forum. Maybe you also have input on this.😀
https://forums.autodesk.com/t5/inventor-forum/printing-with-form/td-p/9291933
Message 8 of 9
Curtis_Waguespack
Hi @FeelGoodGirl
The reason the rule on your other thread was running automatically was this:
ThisDoc.Document.Sheets.Item("Sheet1:1").ExcludeFromPrinting = Not(Sheet1)
where as the version I posted on this thread had the parameter "wrapped" so that it did not trigger the rule when the parameter changed:
ThisDoc.Document.Sheets.Item("Sheet1:1").ExcludeFromPrinting = Not Parameter("Sheet1")
I hope this helps.
Curtis
Message 9 of 9
FeelGoodGirl
I didn't know this yet. I will certainly apply this. Thank you for the tip!
