creating 3d pdf with API
KarlR.J.Wehr
Message 1 of 8
KarlR.J.Wehr
I'm trying to create a 3d pdf with Inventor 2017 API.
With the sample code provided by the Inventor API Help ("Export to 3D PDF API Sample") I am able to create a 3d pdf for a part file (ipt) but the code fails for an assembly document. Running the code for an assembly document only creates an empty 3d pdf.
So, what is missing to deal with assemblies?
I'll be greatful for any help provided...
Karl
Replies (7)
Message 2 of 8
LukeDavenport
Message 3 of 8
KarlR.J.Wehr
Hi Lunk,
thanks for your answer, its working now...
Karl
Message 4 of 8
LukeDavenport
No worries Karl,
Luke
Message 5 of 8
tcp_wegener
 'Publish document.
    Call oPDFConvertor3D.Publish(oDocument, oOptions)
I copied your sample. but I miss the 'oPDFConvertor3D.Publish" method.
"Publish" is not a member of the Automation property, it's just an object.
Do I have to use reflection to invoke the "Publish" method?
Message 6 of 8
Hi Thomas,
It could be that you are not using Inventor 2017, or you are using a previous Inventor object library by mistake?
Luke
Message 7 of 8
tcp_wegener
Hi Luke,
hmm I'm using Inventor 2017. But I don't understand how you can cal a method which isn't existing? The Automation proprty is of "object" and this one don't hhave any method like "publish". It needs another type which have this method, so I can cast it to this type and call the function publish on it.
How do you can manage this issue?
Thomas
Message 8 of 8
tcp_wegener
Hi Luke,
sorry it was my fault. I have too use the late binding stuff.
There is a special keyword in C# for this (instead of using var or object), so:
dynamic oPDFConvertor3D = oPDFAddIn.Automation;
is working 🙂
Thomas
