Remove Special Character from String to form a Filename
A.Acheson
Mentor Mentor
A.Acheson
I am looking to remove the quote symbol ["] used as inch units in a system generated name before using it as a filename.
Dim Name As String
Name = "BW-S-(100)4""
NewName = Name.Replace(""", "")
MessageBox.Show("Name", "Title")
MessageBox.Show("NewName", "Title")
Is it possible? What would the method need to be?
I have tried the string function Replace but """ is not correct.
Any help greatly appreciated.
Thanks.
Regards
Alan
etaCAD
Maybe your are looking for something like this:
 Dim Name As String
 Name = "BW-S-(100)4"""
 Dim NewName As String = Name.Replace("""", "")
 MessageBox.Show(Name, "Title")
 MessageBox.Show(NewName, "Title")
Andreas
etaCAD
A.Acheson
@etaCAD
Thanks for that.
I looked at the rest of the potential strings and found some other invalid characters. I found this helpful function to do that.
https://stackoverflow.com/questions/45458954/replace-invalid-characters-when-saving-excel-as-pdf
Sub Main
 Dim Name As String
 Dim replace_with As String
 replace_with = ""
 Dim NewName As String = clean_filename(Name, replace_with)
End Sub
Function clean_filename(Name As String, replace_with As String)
    Dim inv_chars As String
    Dim cpos As Long
    invchars = "'!""#¤%&/()=?`^*>;:@£${[]}|~\,.'¨´+-"
    For cpos = 1 To Len(invchars)
        Name = Replace(Name, Mid(invchars, cpos, 1), replace_with)
    Next
    clean_filename = Name
	'Return clean_filename
End Function
Regards
Alan
NachoShaw
you can also simplify it
Dim Name As String = Replace("BW-S-(100)4""", Chr(34), "")
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
