iLogic color iFeature in drawing
petr.meduna
petr.meduna
I have a lot of parts from frame generator, each part with inserted iFeature. I would like to change color or highlight this iFeature in drawing. Is there any simple way to do this via iLogic?
Thanks for any suggestion.
dutt.thakar
@petr.meduna
Can you try the below code and see if that is something you are looking for? It will assign red color to each of the iFeatures on your part. I have checked with the part you attached and it is working quite fine.
Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet = oDoc.ActiveSheet
Dim oView As DrawingView = oSheet.DrawingViews.Item(1)
Dim oDC As PartDocument = oView.ReferencedDocumentDescriptor.ReferencedDocument
Dim oCurve As DrawingCurve
For Each oFeat As iFeature In oDC.ComponentDefinition.Features.iFeatures
	Dim obj As Object = oFeat
	For Each oCurve In oView.DrawingCurves(obj)
		oCurve.Color = ThisApplication.TransientObjects.CreateColor(255, 0, 0) 'You can change the numbers here to change the color.
	Next
Next
 Hope this will help you.
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
petr.meduna
Many thanks. That's exactly what I needed.
