Partnumber to custom iproperty
johan.degreef
Advisor Advisor
johan.degreef
As we create a new part, the filename is copied to the partnumber out of the box. We would like also to copy the partnumber to a custom iproperty called PTN_DRAWING on file creation and when partnumber change.
We also work in a Vault 2023 env. So also when a "copy design" is done, the PTN_DRAWING should be filled with the partnumber.
Can anyone help me with this?
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
bradeneuropeArthur
Hi Johan,
Must the custom property be the same as the partnumber?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
If this is the case you need nothing special:
Only fill in the following:
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
johan.degreef
OK Thanks,
I made this change to our template and will monitor if this will do what we want.
bradeneuropeArthur
Otherwise don't hesitate to contact me, can also be private.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
