Partnumber - automatic change by VBA macro
ralfmja
Message 1 of 10
ralfmja
Hello all,
I would like to change partnumber in my project in "automatic mode " like on scheme below:
I have a simple code, but it works only for parts on one BOM level and does not save the scheme 0.001 ... 1.001 etc. (I do not think that's the way):
Sub Zmiana_partnumber()
Dim asmDoc As AssemblyDocument
Set asmDoc = ThisApplication.ActiveDocument
Dim oBom As BOM
Set oBom = asmDoc.ComponentDefinition.BOM
oBom.StructuredViewEnabled = True
oBom.StructuredViewFirstLevelOnly = False
Dim oBOMView As BOMView
Set oBOMView = oBom.BOMViews(2)
Dim compDef As ComponentDefinition
Dim doc As Document
Dim row As BOMRow
Dim prop As Property
Dim NUMER As String
Dim Licznik As Long
NUMER = InputBox("Wprowadź NUMER", "Okno wprowadzania", xx_xxxx)
For Each row In oBOMView.BOMRows
Set compDef = row.ComponentDefinitions(1)
Set doc = compDef.Document
If compDef.Type = kVirtualComponentDefinitionObject Then
Set prop = compDef.PropertySets("Design Tracking Properties")("Part Number")
Else
Set prop = doc.PropertySets("Design Tracking Properties")("Part Number")
Licznik = Licznik + 1
If doc.IsModifiable Then
If prop.Value <> NUMER Then prop.Value = NUMER & "-" & Licznik
Next
End Sub
The next thing would be copying the entire file structure to a new folder, changing the names of files to part numbers 🙂
Is it possible to do this type of macro in VBA at all?
Thanks in advance,
ralfmj
Replies (9)
Message 2 of 10
MechMachineMan
Yes, it's definitely possible.
I suggest your read up more on VBA and search the forums a little better as there are many, many examples of the same thing being done.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 3 of 10
ralfmja
Thank for your reply,
Can you give me similar example of topic which can be useful for me ??
I can't find solution which I can use in my case ...
Many thanks,
ralfmj
Message 4 of 10
MechMachineMan
Below is a link to a thread with multiple different approaches encompassed in it.
https://forums.autodesk.com/t5/inventor-forum/renaming-mass-amounts-of-files/td-p/6801209
Justin K
Message 5 of 10
ralfmja
Sorry but it's not for me. I tried to use many tools but it wasn't good for me ....
Best for me is a design assistant but it's very manual tool.
If you use DA in case a 1000part assembly you must click 1000 time change filename etc. If you do 1 mistake you can start again. You loose many time which can be dedicate for design.
For me the best way is dedicated macro in VBA which I can't write alone ... I need help VBA master who has time for me and my problem 🙂
Message 6 of 10
MechMachineMan
Well thanks for not even looking at the link then.
There are 2 excel vba tools in there that rename parts without the drawback of the Design Assitant stuff.
There is also a lot of code in there that is very similar and requires subtle tweaks to get it to how you want it.
Sounds like you just want somebody to do all of the work for you, for free. An alternative would be to do some learning on VBA/vb.net so you fix it yourself.
Justin K
Message 7 of 10
MechMachineMan
'Code adapted from Owner2229.
Sub Test()
'ThisApplication.SilentOperation = True
Dim oDoc As Document
Set oDoc = ThisApplication.ActiveDocument oPrefix = InputBox("Enter new prefix", "Helper", "XXX")
oInt = 1
oNewName = GetNewName(oDoc.FullFileName)
Call UpdatePartNumber(oDoc, oNewName)
Call oDoc.SaveAs(oNewName, False) Call RenameChildFiles(oDoc) Call oDoc.Save
'ThisApplication.SilentOperation = False
End Sub Dim oInt As Integer
Dim oPrefix As String
Public Sub RenameChildFiles(oDoc As Inventor.Document)
Dim oRefFile As FileDescriptor
For Each oRefFile In oDoc.File.ReferencedFileDescriptors
Dim oName As String
oName = oRefFile.FullFileName
Dim aDoc As Inventor.Document
Set aDoc = ThisApplication.Documents.Open(oName, False)
If aDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
Call RenameChildFiles(aDoc)
Dim oNewName As String
oNewName = GetNewName(oName)
Call UpdatePartNumber(aDoc, oNewName)
Call aDoc.SaveAs(oNewName, False)
Call aDoc.Close (True)
Call oRefFile.ReplaceReference (oNewName)
Next
End Sub
Public Function GetNewName(oName As String) As String
Dim FNP As Integer
FNP = InStrRev(oName, "\", -1)
Dim oPath As String
oPath = Left(oName, FNP) oExt = RIGHT(oName, 4)
Dim oNumber As String
oNumber = oInt.ToString("0000")
GetNewName = oPath & oPref & "-" & oNumber & oExt
End Function
Public Sub UpdatePartNumber(oDoc As Inventor.Document, PN As String)
Dim FNP As Integer
FNP = InStrRev(PN, "\", -1)
PN = Mid(PN, FNP + 1)
PN = Left(PN, Len(PN) - 4)
iProperty(oDoc, "Part Number").Expression = PN
End Sub
Public Function iProperty(oDoc As Inventor.Document, oProp As String) As Inventor.Property
Dim iPro As Inventor.Property
On Error GoTo IPCatch
Dim oPropsets As PropertySets
Set oPropsets = oDoc.PropertySets
Dim oPropSet As PropertySet
Set oPropSet = oPropsets.Item("{32853F0F-3444-11D1-9E93-0060B03C1CA6}")
iProperty = oPropSet.Item(oProp)
IPCatch:
Call oPropSet.Add("", oProp)
End Function
Justin K
Message 8 of 10
ralfmja
Thanks alot for your help Smiley Happy
You have right I don't have knowledge about VB so I count for good people on this forum Smiley Happy I'm very happy that you want help me.
In this way I "wrote" few very helpfull macro which help me in daily work.
I know itsn't easy but I think it's possible.
Below you can see what kind of problem I have with code above.
I know that should convert number of occurance to string (like on my photos in first post)  but we have error .
Message 9 of 10
MechMachineMan
So what that line does is changes the "part id number" into a 4 character digit. Using any available VBA method that turns "1" into "0001" would be fine. Should be able to google it and find an answer quick. I don't have inventor on this computer to test and debug.
Justin K
Message 10 of 10
MechMachineMan
I think this version should function better...
Dim oInt As Integer
Sub Test()
    oInt = 1
    Call oDoc.Save
End Sub
        Dim oName As String
        Call aDoc.Close(True)
        Call oRefFile.ReplaceReference(oNewName)
    Next
End Sub
    Dim FNP As Integer
    Dim oPath As String
    oExt = Right(oName, 4)
    oNumber = Format(oInt, "0000")
End Function
    Dim FNP As Integer
End Sub
    Set iProperty = oPropSet.Item(oProp)
    Exit Function
IPCatch:
End Function
Justin K
