Message 1 of 10
Partnumber - automatic change by VBA macro
- Mute
- Permalink
- Report
Hello all,
I would like to change partnumber in my project in "automatic mode " like on scheme below:
I have a simple code, but it works only for parts on one BOM level and does not save the scheme 0.001 ... 1.001 etc. (I do not think that's the way):
Sub Zmiana_partnumber() Dim asmDoc As AssemblyDocument Set asmDoc = ThisApplication.ActiveDocument Dim oBom As BOM Set oBom = asmDoc.ComponentDefinition.BOM oBom.StructuredViewEnabled = True oBom.StructuredViewFirstLevelOnly = False Dim oBOMView As BOMView Set oBOMView = oBom.BOMViews(2) Dim compDef As ComponentDefinition Dim doc As Document Dim row As BOMRow Dim prop As Property Dim NUMER As String Dim Licznik As Long NUMER = InputBox("Wprowadź NUMER", "Okno wprowadzania", xx_xxxx) For Each row In oBOMView.BOMRows Set compDef = row.ComponentDefinitions(1) Set doc = compDef.Document If compDef.Type = kVirtualComponentDefinitionObject Then Set prop = compDef.PropertySets("Design Tracking Properties")("Part Number") Else Set prop = doc.PropertySets("Design Tracking Properties")("Part Number") End If Licznik = Licznik + 1 If doc.IsModifiable Then If prop.Value <> NUMER Then prop.Value = NUMER & "-" & Licznik End If Next End Sub
The next thing would be copying the entire file structure to a new folder, changing the names of files to part numbers 🙂
Is it possible to do this type of macro in VBA at all?
Thanks in advance,
ralfmj
