Message 1 of 1
Turntable View Rotation
01:59 PM
I have created a turntable VBA macro that works in most cases but is a bit buggy depending on the initial view.
The rotation is about the Z axis and the issues occur when looking directly up or down the axis (Top or Bottom view)
The fault is the view jumps to a new position, the rotation starts doesn't compete 360 deg, then model disappears until clicking in the graphics window.
I could fix it by setting the view to home before rotating but would prefer to use any view if possible to make it more flexible.
Any suggestions how to improve it would be appreciated. 🙂
Public Sub Turntable() ' Define Pi. Dim pi As Double pi = Math.Atn(1) * 4 'Rotation speed in Rad/Sec Dim rotSpeedRad As Double rotSpeedRad = 30 * pi / 180 'Define & check current document type Dim oDoc As Document Set oDoc = ThisApplication.ActiveDocument If oDoc.DocumentType = kDrawingDocumentObject Then GoTo Finished 'Get center point of the model Dim centerPoint As Point Dim minPoint As Point Set minPoint = oDoc.ComponentDefinition.RangeBox.minPoint Dim maxPoint As Point Set maxPoint = oDoc.ComponentDefinition.RangeBox.maxPoint Set centerPoint = ThisApplication.TransientGeometry.CreatePoint( (minPoint.X + maxPoint.X) * 0.5, (minPoint.Y + maxPoint.Y) * 0.5, (minPoint.Z + maxPoint.Z) * 0.5) 'Camera and tuntable rotation Dim camera As Inventor.camera Set camera = ThisApplication.ActiveView.camera Dim totalRot As Double totalRot = 0 'Define rotation increment and axis Dim offsetRad As Double Dim rotAxis As Vector Set rotAxis = ThisApplication.TransientGeometry.CreateVector(0, 0, 1) 'Rotate view Dim upVector As UnitVector Set upVector = ThisApplication.TransientGeometry.CreateUnitVector(0, 0, 1) Do While (totalRot < 2 * pi) offsetRad = 0.05 * rotSpeedRad RotateCam camera, offsetRad, rotAxis, centerPoint, upVector totalRot = totalRot + offsetRad Loop Finished: End Sub Public Sub RotateCam(camera As camera, ByVal offsetRad As Double, rotAxis As Vector, centerPoint As Point, upVector As UnitVector) Dim matrix As matrix Set matrix = ThisApplication.TransientGeometry.CreateMatrix Call matrix.SetToRotation(offsetRad, rotAxis, centerPoint) Dim newEye As Point Set newEye = camera.Eye Call newEye.TransformBy(matrix) camera.Eye = newEye camera.upVector = upVector Call camera.ApplyWithoutTransition End Sub
It is based on code from here:
