Part Sketch Dimensioning Preview / Hang on cursor
bradeneuropeArthur
Mentor Mentor
349件の閲覧回数
3件の返信
メッセージ1/4
bradeneuropeArthur
How do I create a preview of a sketch-dimension created.
the dimension should follow the cursor before the place is picked on the screen.
This is my code so far but the dimension placement is not following the cursor:
Class ThisRule
Dim oInteraction As InteractionEvents
Dim oMouse As MouseEvents
Dim pm As Point2d
Dim sp1 As SketchPoint
Dim sp2 As SketchPoint
Public Sub main
oInteraction = ThisApplication.CommandManager.CreateInteractionEvents
oMouse = oInteraction.MouseEvents
AddHandler oMouse.OnMouseClick, AddressOf oMouse_OnMouseDown
Dim cmd As CommandManager = ThisApplication.CommandManager
sp1 = cmd.Pick(Inventor.SelectionFilterEnum.kSketchPointFilter, "Point 1")
sp2 = cmd.Pick(Inventor.SelectionFilterEnum.kSketchPointFilter, "Point 2")
oInteraction.Start
End Sub
Sub oMouse_OnMouseDown(Button As MouseButtonEnum, ShiftKeys As ShiftStateEnum, ModelPosition As Point, ViewPosition As Point2d, View As Inventor.View)
  Dim p2d As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(ModelPosition.X,ModelPosition.Y)
Dim p As PartDocument = ThisDoc.Document
Dim pc As PartComponentDefinition = p.ComponentDefinition
Dim psk As PlanarSketch = pc.Sketches.Item(1)
Try
	Dim pskd1 As DimensionConstraint = psk.DimensionConstraints.AddTwoPointDistance(sp1, sp2, Inventor.DimensionOrientationEnum.kAlignedDim, p2d, False)
	Catch
	Dim pskd1 As DimensionConstraint = psk.DimensionConstraints.AddTwoPointDistance(sp1, sp2, Inventor.DimensionOrientationEnum.kAlignedDim, p2d, True)
	End Try
oInteraction.Stop
End Sub
End Class
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
0 件のいいね
解決済み
350件の閲覧回数
3件の返信
返信 (3)
メッセージ2/4
C_Haines_ENG
解決済み
I believe you will want to use MouseEvents.OnMouseMove for that application. The ViewPosition variable will give you the coordinates of the mouse so you can continuously update the location of the text.
However, I assume this will have LARGE performance impacts. Worth testing.
メッセージ3/4
Michael.Navara
The performance impact is not so significant. You can try it in this two samples.
0 件のいいね
メッセージ4/4
C_Haines_ENG
Wow that actually works great! Will have to use in the future.
0 件のいいね
