Get selected sketch segments
george1985
george1985
I selected a line and an arc in my Inventor Sketch.
I would like to get this line and the arc via Inventor API.
How can I do that?
I found a method app.ActiveDocument.GetSelectedObject
But I don't know which inputs to use for it.
I also see that there is app.ActiveDocument.SelectSet.
But when I try to call: app.ActiveDocument.SelectSet.Count, it returns 0.
Can someone help me, how to return the selected line and arc inside Sketch?
I would be very grateful for any kind of help.
bradeneuropeArthur
Dim s As Object = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchCurveFilter, "PICK")
If s.Type = ObjectTypeEnum.kSketchArcObject  Then
	MsgBox ("Yes")
This should work.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
george1985
Hi @bradeneuropeArthur ,
Thank you very much for the reply.
Is ThisApplication.CommandManager.Pick raising a dialog, which allows selection?
In my case, the sketch segments are already manually selected in Inventor.
I would like to access that already existing selection.
For example, in AutoCAD we can do it via:
Application.DocumentManager.MdiActiveDocument.Editor.GetSelection().Value.GetObjectIds()
But I don't know how to do it in Inventor.
bradeneuropeArthur
This will do that:
Dim s As SelectSet = ThisDoc.Document.SelectSet
If s.Item(1).Type = ObjectTypeEnum.kSketchArcObject  Then
	MsgBox ("Yes")
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
george1985
Thank you very much for the help!
I got an error at "ThisDoc.Document.SelectSet" saying: "Document property does not exist."
I googled a bit, and it seems ThisDoc.Document is an iLogic function. I apologize for not stating at the very beginning, that I am not using iLogic.
Very strangely I tried again app.ActiveDocument.SelectSet.Count, and it returned "2" instead of "0", as initially.
Then I was able to access both sketch segments with your example code: app.ActiveDocument.SelectSet.Item(1)/(2)
Thank you very much for all your help!
