Override inventor close document
LarsBJepsen
LarsBJepsen
I'm writing an ilogic rule to run on "Close document". Is it possible to override/stop the document close from ilogic in case of specific conditions in the ilogic rule? I would like to have Inventor returning to the document instead of closing it based on specific conditions in the ilogic rule.
Any Suggestions??
bradeneuropeArthur
Maybe it is a solution to re-open it again with coding, after closing!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
WCrihfield
What are your conditions?  Why to you need to use On Close trigger instead of Before Save or After Save triggers?
The Close Document trigger, should actually trigger just before closing the document.
As per the note here Inventor 2020 Help: Event Trigger Refference, it advises you to not change the document within a rule triggered by this.
Wesley Crihfield
(Not an Autodesk Employee)
