Counting "touching" faces by code
Jef_E
Jef_E
Dear,
I am trying to count the number of faces that are touching in the assembly. Currently I use this code, but the result is not satisfying. In the assembly I have a clip placed against the pipe tagent, so only 1 line in the plane is touching the pipe. How can I detect this plane?
    ' Get the active assembly document and its definition.
    Dim asmDoc As AssemblyDocument
    asmDoc = ThisApplication.ActiveDocument
	Dim oDef As AssemblyComponentDefinition
	oDef = asmDoc.ComponentDefinition
	Dim oOccs As New List(Of ComponentOccurrence)
	For Each oOcc As ComponentOccurrence In oDef.Occurrences
		If oOcc.BomStructure = BOMStructureEnum.kNormalBOMStructure Or _
		oOcc.BomStructure = BOMStructureEnum.kPurchasedBOMStructure Or _
		oOcc.BomStructure = BOMStructureEnum.kPhantomBOMStructure Then
			oOccs.Add(oOcc)
	Next
	Dim part1 As ComponentOccurrence
    Dim part2 As ComponentOccurrence
	Dim x As Integer = 0
	Dim oTestString As New List(Of String)
	For i = 0 To oOccs.Count - 2
		part1 = oOccs.item(i)
		'sgBox(part1.Name)
		For Y = i + 1 To oOccs.Count - 1
			part2 = oOccs.item(y)
			MsgBox("Part 1 = " & part1.Name & " | Part 2 = " & part2.Name)
			' Get the bodies in part space as transient bodies.
    		Dim transBrep As TransientBRep
    		transBrep = ThisApplication.TransientBRep
    		Dim body1 As SurfaceBody
    		Dim body2 As SurfaceBody
    		body1 = transBrep.Copy(part1.Definition.SurfaceBodies.Item(1))
    		body2 = transBrep.Copy(part2.Definition.SurfaceBodies.Item(1))
    		' Transform the bodies to be in the location represented in the assembly.
    		transBrep.Transform(body1, part1.Transformation)
    		transBrep.Transform(body2, part2.Transformation)
    		' Imprint the bodies.
    		Dim newBody1 As SurfaceBody
    		Dim newBody2 As SurfaceBody
    		Dim body1OverlapFaces As Faces
    		Dim body2OverlapFaces As Faces
    		Dim body1OverlapEdges As Edges
    		Dim body2OverlapEdges As Edges
   			ThisApplication.TransientBRep.ImprintBodies(body1, body2, True, newBody1, newBody2, _
                                                     	body1OverlapFaces, body2OverlapFaces, _
                                                     	body1OverlapEdges, body2OverlapEdges,1)
			' TODO: exception mating of bolt/nuts/washers
			' TODO: wat met losse onderdelen aanduiding? Negeren? Davit = ook las?
			' TODO: recusief met sub assemblies? BOM volgorde?
			MsgBox("body1OverlapFaces = " & body1OverlapFaces.count)
			MsgBox("body2OverlapFaces = " & body2OverlapFaces.count)
			MsgBox("body1OverlapEdges = " & body1OverlapEdges.count)
			MsgBox("body2OverlapEdges = " & body2OverlapEdges.count)
			If body1OverlapFaces.Count > 0 Then
				Dim oString As String = "Las: " & part1.Name & " tegen " & part2.Name
				oTestString.add(oString)
				x = x + 1
			Else
				If body1OverlapEdges.Count > 0 Then
					x = x + 1
		Next
	Next
MsgBox("Aantal lassen: " & x)
For Each oString As String in oTestString
	MsgBox(oString)
Next
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
JelteDeJong
i found an post on a simmular topic (Find Touching Area of Two Coplanar Faces) but it looks to difficult for me.
Maby this simpler solutions work for you:
  1. You can try to use the  collision detection from inventor.
  2. The other option is to look at all the constraints. (i guess that your welds are always constarint.) if the offset of a mate or tangent constarint is 0 then you problay need to weld. see iLogic script below:
Dim doc As AssemblyDocument = ThisDoc.Document
Dim constarint = doc.ComponentDefinition.Constraints.Item(1)
For Each constraint As AssemblyConstraint In doc.ComponentDefinition.Constraints
    If (constraint.Type = ObjectTypeEnum.kMateConstraintObject) Then
        Dim mate As MateConstraint = constraint
        If (mate.Offset.Value < 0.0001) Then
            MsgBox(String.Format("occurence {0} is toching occurence {1}",
                            mate.OccurrenceOne._DisplayName, mate.OccurrenceTwo._DisplayName))
    ElseIf (constraint.Type = ObjectTypeEnum.kTangentConstraintObject) Then
        Dim mate As TangentConstraint = constraint
Next
Jelte de Jong
Blog: hjalte.nl - github.com
Jef_E
- suggestion 1 Will not work, this method adds extrude features, and not all faces are planar.
1) Colision detection may work havent heard of it. we use inventor 2014, is this available?
2) Also is reling on the fact that a constraint needs to be in place in order to have a check. Skeleton models that use ground and root are not considered and thus not fool proof;
My method is working but not taking tangent plane to round into  account all other matching faces are considered...
Inventor 2014 SP2
WCrihfield
Here are a couple of links explaining the similar features built into Inventor.
About Interference between Components
Detect contact between assembly components
I don't recall exactly when these abilities / tools were added into Inventor.
Wesley Crihfield
(Not an Autodesk Employee)
