Numeric paramteres precision display
bshbsh
bshbsh
when I type in a numerical parameter through the GUI, let's say for example a hole depth of 20mm, it will display as "20mm" and when queried through VBA it will be "2" (centimeters).
However, when I change the value through VBA, it will be shown on the GUI as "20.000000 mm" and when read by VBA it will be 2.00000 cm as well.
I have this problem with changing every kind of numerical parameters through VBA, and I have no idea how to do this correctly.
Could anyone help me please? Thanks in advance.
bradeneuropeArthur
Can you make a screenshot of the parameterbox in inventor.
Maybe I have the solution!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bshbsh
Here's an example what I mean.
This is what the value of the thickness and the hole diameter looks like when typed in via these dialog boxes:
And after running this macro (a simplified example of how I want to change these parameters)
Public Sub ChangeParameters()
    Dim ThicknessBefore, ThicknessAfter, HoleDiaBefore, HoleDiaAfter As String
    ThicknessBefore = ThisApplication.ActiveEditDocument.ComponentDefinition.Thickness.Expression
    HoleDiaBefore = ThisApplication.ActiveEditDocument.ComponentDefinition.Features.HoleFeatures.Item(1).HoleDiameter.Expression
    ThisApplication.ActiveEditDocument.ComponentDefinition.Thickness.Value = 0.5
    ThisApplication.ActiveEditDocument.ComponentDefinition.Features.HoleFeatures.Item(1).HoleDiameter.Value = 1.5
    ThicknessAfter = ThisApplication.ActiveEditDocument.ComponentDefinition.Thickness.Expression
    HoleDiaAfter = ThisApplication.ActiveEditDocument.ComponentDefinition.Features.HoleFeatures.Item(1).HoleDiameter.Expression
    MsgBox (ThicknessBefore & vbNewLine & ThicknessAfter & vbNewLine & HoleDiaBefore & vbNewLine & HoleDiaAfter)
End Sub
The parameter Expressions change (obviously), but the display unnecessary tailing decimal zeroes. Also the parameters DecimalPrecision is set to 3, so it should only display at most 3 zeroes.
bradeneuropeArthur
Try this:
    ThisApplication.ActiveEditDocument.ComponentDefinition.Thickness.Expression = "0.7 mm"
    ThisApplication.ActiveEditDocument.ComponentDefinition.Features.HoleFeatures.Item(1).HoleDiameter.Expression = "1.6 mm"
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
bshbsh
Thanks, that of course works, but do I really have to construct the expressions myself to do that? Isn't there an evaluator function somewhere that returns the expression in the proper format from the value?
bradeneuropeArthur
change to this:
    ThisApplication.ActiveEditDocument.ComponentDefinition.Thickness.Expression = "0.7" & ThisApplication.ActiveEditDocument.ComponentDefinition.Thickness.Units
    ThisApplication.ActiveEditDocument.ComponentDefinition.Features.HoleFeatures.Item(1).HoleDiameter.Expression = "1.6" & ThisApplication.ActiveEditDocument.ComponentDefinition.Features.HoleFeatures.Item(1).HoleDiameter.Units
    'ThisApplication.ActiveEditDocument.ComponentDefinition.Features.HoleFeatures.Item(1).HoleDiameter.Units
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
