Network License Not Available
brent_e_barbour
Message 1 of 11
brent_e_barbour
I just upgraded a network version of Inventor 2018 to 2019.  When I launch it for the first time after the install I get “Network License Not Available.”  I’m using “2080@server name” as directed.  I tried using both the server name and the IP address.  I generated a new license file using both the server name and the IP address.  I used the inventor install on the server to verify the license manager is current and it indicates it’s already installed.  Nothing I try works.
Replies (10)
Message 2 of 11
bradeneuropeArthur
Same issue here.
Update your inventor server to 2019.
With all updates....
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 11
brent_e_barbour
What update?  The Autodesk Desktop App doesn't see any updates so I presume my workstation is up to date.  The "server" only has 2019.1 Vault Basic (server) and the license manger (LM) on it.  I don't see a way to check for updates in LM nor do I see LM updates in my subscription account.
Message 4 of 11
bradeneuropeArthur
FLEXlm licence manager to the new version and it will be accepted.
This afternoon we solved it this way...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 11
brent_e_barbour
Is FLEXlm different from LMtools by Flexera Software used for 2018?  When using the Inventor 2019 CD on the server, the setup utility says the License Manager is already installed so I assume it's the same.  If not, where can I find FLEXlm?
Message 6 of 11
bradeneuropeArthur
Have you updated the LM?
Seems to be the same FLEXlm licence manager and your LM!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 11
brent_e_barbour
As I said earlier, I'm not seeing any updates.  If you know of any I'm not seeing, please share where I can get them.  What version of FLEXlm are you up to?  Mine is below...LMtools.jpg
Message 8 of 11
bradeneuropeArthur
Need to check tomorrowmorning.
Is that fine for you?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 11
brent_e_barbour
Your help is greatly appreciated!  If you need to get back to me tomorrow morning, I look forward to your response.  Meanwhile, I'm going to continue you work at it because there's not much else I can do until my Inventor is back up.  Thank you!
Message 10 of 11
brent_e_barbour
Going on bradeneurope's suggestion, I saw no way to update the LMtool (or FLEXlm?).  So, I uninstalled it and reinstalled the version provided in the Inventor 2019 install utility.  A later version of the LMtool was installed.  Everything seems to be working properly now.  Thanks for your help bradeneurope!LMtools2.jpg
Message 11 of 11
bradeneuropeArthur
@brent_e_barbour
Your thanks are appreciated very much.
This is exactly  what we have done this afternoon.
Good to hear that it was solved and that it was that simple.
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
