Newbie want to know how do program a simple ilogic formrules
kadscad
kadscad
Hi all
I want to create a part that is a wall with studs. As the wall changes length it adds or subtracts studs.
I know how to create a simple form that will change the basic parameters I just don't know how to get started on the other part above.
it's a 96" wall.  The end studs will always remain
If the wall is 96" then all studs remain
If its <= then 84" Stud #1 is removed
If its <= then 68" Stud #1 and 2  is removed
If its <or= than 52" Stud #1 , 2 & 3 is removed
and so on and  so and so on
I named each  stud extrusion
Can I rename the parameter name too instead of D61 or whatever number and not screw things up.
Or is that just extra unnecessary work since the parameters are listed by parameters and names in the rule dialog
Kirk
Inventor 2023
bradeneuropeArthur
Basically you don't need ilogic or programming for this!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
kadscad
Thanks but I knew that much. I want a tip on how to get started
Kirk
Inventor 2023
bradeneuropeArthur
With or without programming?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
kadscad
I would say the easiest way possible that can be used over and over again
If I dont need to progam it that fine as long as I dont have to go back and manually suppress  elements manuallly
Kirk
Inventor 2023
bradeneuropeArthur
Out of the box inventor is the easiest and best way. So without programming.
Will come back to it earliest tomorrow.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
