Need to retrieve Type data of custom iPropertis using iLogic
RoyWickrama_RWEI
Advisor Advisor
Message 1 of 24
RoyWickrama_RWEI
I am developing part of my rule to handle custom iProperties.
I need to retrieve "Type" data of iProperties.
Today.pngMy
My current rule (sample) is attached here to: I need to do with iProperty type information.
I appreciate if someone help me.
Replies (23)
Message 2 of 24
bradeneuropeArthur
Do you need to know/read the type of a selected custom property or do you need to set/define the type of a custom property?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 24
chandra.shekar.g
Autodesk Support
Autodesk Support
@RoyWickrama_RWEI,
Try below iLogic code to add custom properties depending on data type. Make sure that value is entered according data type.
For example:
Boolean - 'True - Yes' or 'False - No'
Date - 07-12-2018
Number - 123456
String - Any string value
Sub Main()
oRuleNo = "iL0080"
Dim X_PaintCode As String
X_PaintCode = "Paint Code"
Dim X_Size As String
X_Size = "Size"
Dim X_Galvanized As String
X_Galvanized = "Galvanized"
Dim X_Date_Completed As String
X_Date_Completed = "Completion Date"
Dim oProp_Array As New ArrayList
oProp_Array.Add(X_PaintCode)
oProp_Array.Add(X_Size)
oProp_Array.Add(X_Galvanized)
oProp_Array.Add(X_Date_Completed)
'define custom prp[erty collection
oCustomPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
For Each X_oProp_Array In oProp_Array
	Try
	'set property value
	oProp = oCustomPropertySet.Item(X_oProp_Array)
	Catch
	MessageBox.Show("Prop exists: No", "Title")
	' Assume error means not found so create it
	oCustomPropertySet.Add("", X_oProp_Array)
	End Try
	oYN = MessageBox.Show("Do you need to assign TYPE for " & X_oProp_Array & "?", "Title", MessageBoxButtons.YesNo)
	If oYN = vbYes Then oType_Assign(oRuleNo, X_oProp_Array)
Next X_oProp_Array
iLogicVb.UpdateWhenDone = True
End Sub
Sub oType_Assign(oRuleNo, X_oProp_Array)
oSubName = "ASSIGN TYPE"
Dim oProp_String As String
oType_String = "String"
Dim oProp_Dbl As Double
oType_Dbl = "Double"
Dim oProp_Bool As Boolean
oType_Bool = "Boolean"
Dim oProp_Date As Date
oType_Date = "Date: mm/dd/yyyy"
Dim oTypes_Array As New ArrayList
oTypes_Array.Add(oType_String)
oTypes_Array.Add(oType_Dbl)
oTypes_Array.Add(oType_Bool)
oTypes_Array.Add(oType_Date)
oTypes_Selected = InputListBox("SELECT TYPE:", oTypes_Array, oTypes_Array(0), oRuleNo, X_oProp_Array)
Dim oTime As DateTime
Select Case oTypes_Selected
Case oType_String
	X_oProp_Data = InputBox("Enter data for " & X_oProp_Array & ": ", oRuleNo, "STRING DATA ONLY") 'no default value
 	iProperties.Value("Custom", X_oProp_Array) = X_oProp_Data
Case oType_Dbl
	X_oProp_Data = InputBox("Enter data for " & X_oProp_Array & ": ", oRuleNo, "NUMERICAL DATA ONLY") 'no default value
	Dim numeric As Double
	numeric = Convert.ToDouble(X_oProp_Data)
	iProperties.Value("Custom", X_oProp_Array) = numeric
Case oType_Bool
	X_oProp_Data = InputBox("Enter data for " & X_oProp_Array & ": ", oRuleNo, "Boolean only") 'no default value
	Dim bool As Boolean
	bool = Boolean.Parse(X_oProp_Data)
	iProperties.Value("Custom", X_oProp_Array) = bool
Case oType_Date
	X_oProp_Data = InputBox("Enter data for " & X_oProp_Array & ": ", oRuleNo, Now.ToString("MM/dd/yyyy")) 'no default value
	oTime = DateTime.Parse(X_oProp_Data)
	iProperties.Value("Custom", X_oProp_Array) = oTime
End Select
''set custom property values
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 4 of 24
RoyWickrama_RWEI
Thanks a for for the reply.
I will study the whole rule and revert to you later.
Message 5 of 24
RoyWickrama_RWEI
Thanks for the question. Basically, currently, I need to view  (with a message box prompt) the type of the iProperty. However, I may explore all the options able to do. I will get back to you again.
Message 6 of 24
RoyWickrama_RWEI
Again, thanks for the fix. It is fine. With the help, I was able to add some try .. catch ... end try to avoid rule crashing.
I also need to extract type with a line of rule like below:
MessageBox.Show("TYPE: " & iProperties.Type("Custom", X_oProp_Array), "Title")
 But, error comes:
... Type' is not a member of 'Autodesk.iLogic.Interfaces.IiProperties'
Could you suggest a fix. Thanks.
Message 7 of 24
chandra.shekar.g
Autodesk Support
Autodesk Support
@RoyWickrama_RWEI,
Are you looking for value type of property or type of iProperty?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 8 of 24
RoyWickrama_RWEI
Thanks for responding.
Yes. I nee d to do with the following:
'oTypes_Array.Add(iProperties.Type("Custom", X_oProp_Array))
The first line commented because it does not go through.
Please reply.
Message 9 of 24
RoyWickrama_RWEI
@chandra.shekar.g wrote:
@RoyWickrama_RWEI,
Thanks and regards,
Yes. My previous reply was not clear, I guess.
Message 10 of 24
RoyWickrama_RWEI
I explored a little bit more again. I think, this is not possible.
MessageBox.Show("Message, Before: " & X_oProp_Array, "Title")
oXX = oCustomPropertySet.Item(X_oProp_Array)
MessageBox.Show("Message" _
& vbLf & "Name: " & oXX.Name _
& vbLf & "Value: " & oXX.Value _
& vbLf & "Type: " & oXX.Type, "Title")
Type is retrievable, but useless because it is the same for all types (0339072 for all Text, Date, Number, Yes or No).
Several years ago, I had more problems like this, then I gave up. Coming back (I need to learn), I see Autodesk Inventor still has areas to develop.
Just information. Please let me know if you have some information.
Thanks.
Message 11 of 24
RoyWickrama_RWEI
You have helped me a lot, and I thought not to disturb you: this is my headache.
I am getting around it, will let you know soon.
Thanks for your help.
Message 12 of 24
RoyWickrama_RWEI
I accepted your code as a solution as it led me to get around my current need.
Attached hereto is the code I developed with your help.
Let me know if you have any comments (if you don't bother spending time). Thanks a lot.
Message 13 of 24
RoyWickrama_RWEI
Replacing the data roe in the array:
oTypes_Array.Add(oType_Int)
For Each oItem In oTypes_Array
	If oItem = oXX_Type Then
	oType_Edit = oXX_Type
Next oItem
oTypes_Selected = InputListBox("SELECT TYPE:", oTypes_Array, oType_Edit, oRuleNo, oProp_Array_Selected)
Message 14 of 24
chandra.shekar.g
Autodesk Support
Autodesk Support
@RoyWickrama_RWEI,
Try below iLogic code to get data type of custom property.
Sub Main()
	Dim doc = ThisDoc.Document
	Dim oProperty As Inventor.Property
	oProperty = doc.PropertySets.Item("Inventor User Defined Properties").Item("oText")
	Dim oValue As String
	oValue = oProperty.Value
	Try
		oTime = DateTime.Parse(oValue)
		MessageBox.Show("Value is Date Type", "Property type")
		Exit Sub
	Catch
		 GoTo Numeric
	End Try
	Numeric:
	Try
		Dim oNumber As Integer
		oNumber = Convert.ToInt16(oValue)
		MessageBox.Show("Value is Number Type", "Property type")
		Exit Sub
	Catch
		  GoTo StringValue
	End Try
	StringValue :
	If oValue = "True" Or oValue = "False" Then
		MessageBox.Show("Value is Boolean Type", "Property type")
	Else
		MessageBox.Show("Value is Text Type", "Property type")
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 15 of 24
ReneRepina
one question about this topic.
We use custom iproperty for identification. It is a string parameter (because it can be just a 6-digit number or containing other symbols and letters).
Sometimes problem occurs that it writes 6-digit number as NUMBER, except as string. It there any possible way to check that with iLogic? Problem is that if I use above code, value of 123456, can be either a number or string, so if I try to parse or convert, this always go through, so I cannot distinguish between integer and string.
One way can be to store the value and enter it as "123456", but that dirties the document and we do not wanna do that if it is not needed. So in this situation, I would compare types, if it is a number, rewrite is as string. Is this possible?
Message 16 of 24
NachoShaw
Hey
I put this together for when i am working with Properties to make sure i get the correct type. I use it VB.Net but im sure you could get it to work in iLogic
Friend Function GetPropertyType(ByRef PropVal As String) As Object
Dim dbl As Double
If Double.TryParse(PropVal, NumberStyles.Float, CultureInfo.InvariantCulture, dbl) Then Return dbl
Dim bln As Boolean
If Boolean.TryParse(PropVal, bln) Then Return bln
Dim dte As Date
If Date.TryParse(PropVal, dte) Then Return dte
Dim int As Integer
If Integer.TryParse(PropVal, int) Then Return int
Return PropVal
End Function
to use in a function
Dim PropertyType As Object = GetPropertyType(PropertyValue)
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Message 17 of 24
ReneRepina
@NachoShaw
Thanks for the reply. Unfortunately this won't work in my case, because if you have a string "123456" and try parse it to "Double" or "Int" it will return true, so you cannot distinguish the data type inside iProps (at least I do not know the command).
In my situation, I have a value of "123456" (it can be a text or a number) and I need to distinguish between those two types, because I need explicitly as text type. So basically check if it is a string leave it like it is and if it is a number, convert it to string.
Message 18 of 24
NachoShaw
Ok. So if you need the number as string regardless, why not convert it
Dim dVal as Double = 123456
Dim scale as String = "123456"
Try
   Convert.ToString(dVal)
   Convert.ToString(sVal)
Catch ex As Exception
End Try
Nacho
Message 19 of 24
ReneRepina
@NachoShaw
I need this for iProps. If I use "Convert.ToString(value)", data type in iProps still stays as it is. For example, if I have a 123456 as number, convert it to string and write the value to iProp, it will still be as a number.
But, this works though:
iProperties.Value("Custom", "test") = Convert.ToString(iProperties.Value("Custom", "test"))
One of the problems I am having currently is that I do not want to "dirty" the file, if iProp is already as text. I would need a boolean to compare data types. If data is a "number" data type, covert it (as you suggested) OR delete and write parameter again in text and if it is already a text, do not do anything, therefor skipping convert (and not dirty the file).
Message 20 of 24
NachoShaw
Hey
it shouldnt be still a number though. if you are adding as a number 123456, it will be a number but if you add as a string "123456" it will be a string.
I did a bunch of iProperty work recently and the function i made to determine the Type was needed because all of my values were originally added as text, even long numbers. I needed the Type check to add in the type and then added the value as that iProperty value as a Type like this:
Dim customPropSet As Inventor.PropertySet = Doc.PropertySets.Item("Inventor User Defined Properties")
Dim ValueIn As Object = GetPropertyType(PropertyValue)
Try
   Dim prop As Inventor.Property = customPropSet.Add(ValueIn, PropertyName)
Catch ex As ArgumentException
   Dim prop As Inventor.Property = customPropSet.Item(PropertyName)
   prop.Value = ValueIn
End Try
i was setting the ValueIn as the as the value and the type by using the GetPropertyType() function and then when passing into the iProperties, it was setting the value as they Type.
Nacho
