How to hide the first part in an assembly with VBA
lzs013
lzs013
How to hide the first part in an assembly with VBA?Hide the part pointed by the arrow in the picture。1.png
bradeneuropeArthur
Public Sub main()
Dim a As AssemblyDocument
Set a = ThisApplication.ActiveDocument
Dim b As AssemblyComponentDefinition
Set b = a.ComponentDefinition
b.Occurrences.Item(1).Visible = False
End Sub
for  ilogic
Public Sub main()
'Dim c As Occurrence
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
dgreatice
beware,
if that part is not first placement 😄 (user have edit with Ground command)
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
lzs013
THX!
