Count unique bodies in the IAM
Maxim-CADman77
Advisor Advisor
Maxim-CADman77
I'm trying to write an iLogic app for processing bodies of the active Assembly.
My minimal goal is just to count unique bodies.
My current best bet is:
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
Dim MsgBody As String=""
Dim OccIndex As Integer=0
Dim BdQTY As Integer=0
For Each oOcc As ComponentOccurrence In oAsmDoc.ComponentDefinition.Occurrences
BdQTY=BdQTY+oOcc.SurfaceBodies.Count
OccIndex=OccIndex+1
MsgBody=MsgBody & "#" & OccIndex & ":" & vbCrLf & "Name : " & oOcc.Name & vbCrLf & "Type : " & oOcc.Type & vbCrLf & "BodyQTY = " & oOcc.SurfaceBodies.Count  & vbCrLf & vbCrLf
Next
MsgBox(MsgBody,, BdQTY & " bodies found in " & oAsmDoc.ComponentDefinition.Occurrences.Count & " components:")
For standard sample weldment-assembly Carriage.iam it gives me wrong result (6 bodies) while expected is 10 bodies (reported by BSCT after pressing Ctrl+F7) :
I guess I have done at least two mistakes:
1. I am not skipping the body for duplicated occurences
2. I'm not counting bodies of sub-assemblies
and may be I should more carefully process weld-beads
As for 2 if I don't missed some easier way (some ready for use property) i probably need to add some recursion procedure (never did this before yet) , right?
Could please somebody point  me in the right direction..
PS: My further goal - get body-complexity rating i.e.. report N (let say five) most complex bodies sorted for decreasing FaceCount
Please vote for Inventor-Idea Text Search within Option Names
chandra.shekar.g
Autodesk Support
Autodesk Support
@Maxim-CADman77,
Hoping that below iLogic code may help to get count of bodies in an assembly.
Dim oDoc As Document
For Each oDoc In oAsmDoc.AllReferencedDocuments
BdQTY=BdQTY+ oDoc.ComponentDefinition.SurfaceBodies.Count
OccIndex=OccIndex+1
MsgBody=MsgBody & "#" & OccIndex & ":" & vbCrLf & "Name : " & oDoc.DisplayName & vbCrLf & "Type : " & oDoc.DocumentType & vbCrLf & "BodyQTY = " & oDoc.ComponentDefinition.SurfaceBodies.Count  & vbCrLf & vbCrLf
Next
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
