Message 1 of 12
- Mute
- Permalink
- Report
I need to retrieve the solid body information from browser of a derived part.
I request someone to help me.
Thanks.
Thanks.
See one of them in my shortcuts Derive I-properties! :
I can help you with the code if you need..
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Thanks for the reply. I found a great rule for extracting iProperties to the derived part.
Also, I am trying to extract the solid body name from within the derived part. Please see below:
Could you help.
Thanks.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
That's fine. Take your time.
Thanks.
I think this is what you need:
Public Sub SuppressLinkderivedpart() Dim oInvApp As Inventor.Application Set oInvApp = ThisApplication ' Set a reference to the Active document as a Part Dim oInvPartDocument As PartDocument Set oInvPartDocument = oInvApp.ActiveDocument ' Set a reference to the part component definition Dim oInvPartCompDef As PartComponentDefinition Set oInvPartCompDef = oInvPartDocument.ComponentDefinition ' Set a reference to the derived part component Dim oDerivedPart As DerivedPartComponent Set oDerivedPart = oInvPartCompDef.ReferenceComponents.DerivedPartComponents.Item(1) MsgBox oDerivedPart.SolidBodies.Item(1).Name End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Thanks for the reply. I developed my rule to open and reference document and edit the solid body required. As I have the solid body name (copied to clip board), I have the option to turn all other solid bodies turned off and continue editing.
I was trying to do it for handling parts with multiple derived parts and each derived parts having many solid bodies. for now, I gave up (I am not a good programmer).
Thanks again for your help.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
I was thinking in case The part has several derived parts with each derived part has more than one solid body incorporated. More than one solid body with a single derived part is likely OK, but I could not do for more than one derived part.
Could you provide me with some guide lines.
You have already solved my problem. Thanks a lot.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
with this you can:
Public Sub DeleteLinkderivedpart() Dim oInvApp As Inventor.Application Set oInvApp = ThisApplication ' Set a reference to the Active document as a Part Dim oInvPartDocument As PartDocument Set oInvPartDocument = oInvApp.ActiveDocument ' Set a reference to the part component definition Dim oInvPartCompDef As PartComponentDefinition Set oInvPartCompDef = oInvPartDocument.ComponentDefinition ' Set a reference to the derived part component Dim oDerivedPart As DerivedPartComponent 'Set oDerivedPart = oInvPartCompDef.ReferenceComponents.DerivedPartComponents.Item(1) For Each oDerivedPart In oInvPartCompDef.ReferenceComponents.DerivedPartComponents Dim msgbresult As String msgbresult = MsgBox(oDerivedPart.Name, vbYesNo,, "Delete this one?") If msgbresult = VbYes Then oDerivedPart.Delete End If Next End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Thanks a lot. Information in this code is greatly helpful in my iLogic purists.
