How to Properly Loop through ReferencedDocuments.
sgwilliams
sgwilliams
I have a part number called abc-123. The relevant files include an idw and 3-4 ipt files one for each operation the part goes through in the manufacturing process. The file names are as follows:
Drawing filename "abc-123.idw"
Model Files Include:
Finished Part name "abc-123.ipt"
op-10 part name "abc-123_op10.ipt"
op-20 part name "abc-123_op20.ipt"
op-30 part name "abc-123_op30.ipt"
op-40 part name "abc-123_op40.ipt"
Here is my code:
Dim app As Application: Set app = ThisApplication
Dim doc As Document: Set doc = app.ActiveDocument
Dim fso As New Scripting.FileSystemObject
Dim ffName: Set ffName = doc.fullFileName 'Gets path with filename and extension
Dim ext: Set ext = fso.GetExtensionName(ffName) 'Gets just the extension
Dim fName: Set fName = fso.GetFileName(ffName) 'Gets just the filename with extension
Dim pNo: Set pNo = Left(fName, Len(fName) - Len(ext) - 1)
If TypeOf doc Is DrawingDocument Then
Dim imFile As Document 'inventor model file Set imFile = doc.ReferencedDocuments(1) 'The (1) represents the Item1 found in the Locals path tree Set designInfo = imFile.PropertySets.Item("Design Tracking Properties") Dim rdpNo As Property Set rdpNo = designInfo.Item("Part Number") 'Referenced Document Part Number
The problem I'm running into is that all the idw files don't always have the Finished part name as Item1:
 there are actually 5 items. Sometimes it will be Item2, Item3, Item4 or Item5. I have to use the PropertySets from the Finished PartName as this is where we store all our iProperties Data.
So my Plan was to do an If statement that compares "pNo" to rdpNo" if they match then use that item PropertySet.
Just looking for some guidance on if this is the correct way to achieve this or do I need to code it differently.
Work Station : Custom built, Liquid Cooled, Asus Pro WS X570-ACE Motherboard; AMD Ryzen 9 3900X 3.8 GHz 12-Core Processor; ASUS TUF Gaming NVIDIA GeForce RTX 3060 V2 OC Edition Video Card; 32 GB CORSAIR Dominator Platinum DDR4-2132 Memory ; Samsung 850 EVO 1TB SSD Drive.
sgwilliams
I figured it out. Here is the code that works.
    Dim imFileCount As Variant
        imFileCount = doc.ReferencedDocuments.Count
        For i = 1 To imFileCount
            Dim imfFile As Variant
                imfFile = doc.ReferencedDocuments(i).FullFileName
            Dim rDoc As Document
            Set rDoc = doc.ReferencedDocuments(i)
            Dim fExt As String
                fExt = fso.GetExtensionName(imfFile)
            Dim imFile As String
                imFile = fso.GetFileName(imfFile)
        Next
        Dim rDocFN As Variant
        rDocFN = pNo + "." + fExt
        Dim mFile As Variant
        mFile = imFile
        Dim x As Integer
        x = StrComp(rDocFN, mFile)
        If x = 0 Then
             Set engInfo = rDoc.PropertySets.Item("Design Tracking Properties") 'get the checkedBy and authorBy approval Property Set
             Set rdpNo = engInfo.Item("Part Number") 'Referenced Document Part Number
             Dim checkedBy As Property
             Set checkedBy = engInfo.Item("Checked by")
             Dim authorBy As Property
             Set authorBy = engInfo.Item("Engr Approved By")
             Set salesInfo = rDoc.PropertySets.Item("Inventor User Defined Properties") 'get the salesBy approval Property Set
             Dim salesBy As Property
             Set salesBy = salesInfo.Item("Sales Rep.")
        Else: Return
sgwilliams
Ok, I had the for loop, next statement in the wrong place and had a return statement that did not belong. here is the final working code.
            Dim fExt As String
           'Next
            mFile = imFile
            Dim x As Integer
           If x = 0 Then
        Next
