Need help with old add-in
karthur1
Mentor Mentor
karthur1
I have an add-in that I have used with Inventor for the last 10+ years. Now with Inventor 2024, I cannot get it to load (doesnt show up under Add-ins). I have looked at the .addin file, but I do not see anything there to keep it from loading.
Could I get someone to take a look at this and see if you could maybe get it to load in Inventor?  When its installed, here are the files it loads.
Zip file attached.
Kirk
bradeneuropeArthur
Hi @karthur1 ,
That has been a long time.
The same questions I have had e few months ago too for similar old add in.
It was easy to fix for at that moment with using this technique
https://help.autodesk.com/view/INVNTOR/2024/ENU/?guid=GUID-CFFA5CC6-38E6-4ACD-A2BC-8B8732727996
I will have a look at it, but can you send the vb.net source project!?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Frederick_Law
I ran the Install exe, can't find where the files are installed.
Found it.
It installed to: C:\Program Files\Autodesk\Macros\ADrawingResourcesNET
Copy or move "ADrawingResourcesNET" folder to %AppData%\Autodesk\ApplicationPlugins will load it after IV restart.
karthur1
@bradeneuropeArthur wrote:
Hi @karthur1 ,
Wish I had the source, but unfortunately, I don't have it.
I did review the .addin file.  Sometimes this will have a line that sets the maximum version, but this one does not have that.
karthur1
Found it.
Many Thanks.  Will give it a go when I get a chance later.
bradeneuropeArthur
Can you send the .dll file and the .addin file?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Frederick_Law
ZIP of the folder created by install program.
