Multivalue parameter arrayList throwing error when assigning an array
Hi there!
I'm getting an "Object reference not set to an instance of an object." error when attempting to assign an array to a multivalue parameter.
The multivalue parameter is "test" and the array I'm attempting to assign to the "test" parameter is the form array.
I've attempted to:
- simply assign the materialStyle array
- populate the formArray using the "add" function with the materialStyle array
- directly assign the materialStyle array TO the formArray
I'm simply not good enough to figure out what I am doing wrong.
Dave
AddReference "System.Linq" AddReference "System.Xml" AddReference "System.Xml.Linq" AddReference "System.Core" Imports System.Linq Imports System.Xml.Linq Imports System.Xml.Schema Imports System.Xml Sub Main Dim feedXML As XDocument Dim xmlDocName As String = "C:\Users\drouthier\Desktop\sheetmetalrules.xml" feedXML = XDocument.Load(xmlDocName) materialStyle = xmlFeedFilter(feedXML, "MaterialStyle") Dim formArray As New ArrayList() formArray.clear For x = 0 To UBound(materialStyle) formArray.add (materialStyle(x)) Next x MultiValue.List("test") = formArray End Sub Public Function xmlFeedFilter(feedXML As Object, attributeName As String) Dim x As Integer Dim z As Integer Dim objectArray(0) As String For Each oElement As XElement In feedXML.Descendants() For Each oAttribute As XAttribute In oElement.Attributes() If oAttribute.Value = attributeName z = 0 For x = 0 To UBound(objectArray) If UBound(objectArray) = 0 Then Exit For Else If objectArray(x) = oElement Then z = 1 Exit For End If End If Next x If z = 0 Then objectArray(UBound(objectArray)) = oElement ReDim Preserve objectArray(UBound(objectArray) + 1) End If End If Next oAttribute Next oElement BubbleSortAscending(list:= objectArray) xmlFeedFilter = objectArray End Function Public Sub BubbleSortAscending(list() As Object) ' Sorts an array using bubble sort algorithm ' Ascending ' perform the call from the main as ' BubbleSort (list:=array) Dim First As Long, Last As Long Dim i As Long, j As Long Dim Temp As Object First = LBound(list) Last = UBound(list) For i = First To Last - 1 For j = i + 1 To Last If list(i) > list(j) Then Temp = list(j) list(j) = list(i) list(i) = Temp End If Next j Next i End Sub
