Create a list in Excel with the properties of all the sheets whit ilogic
andrescastellanosint
Message 1 of 13
Hello, I need to create a list in Excel containing all the iproperties of all the Sheets of drawings with ilogic.
thank's
Replies (12)
Message 2 of 13
bradeneuropeArthur
What do you mean with all the sheets.
All the sheets in one drawing?
All the drawings in one folder?
What do you mean with the iproperties of the sheets?
Sheets have no iproperties, drawing have!?
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 13
hello, my Drawing has more than one sheet, and each one has a different description, I would like to extract a list in excel where this information wasimage001.png
Message 4 of 13
This is code:
On Error Resume Next
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oSheetS As Sheets
Dim oPromptEntry
Dim oALLSheet
oCurrentSheet = oDoc.ActiveSheet.Name
i = 1
For Each oSheet In oDoc.Sheets
  i = i+1
  ThisApplication.ActiveDocument.Sheets.Item(i).Activate
       oTitleBlock=oSheet.TitleBlock
    oTextBoxes=oTitleBlock.Definition.Sketch.TextBoxes
    For Each oTextBox In oTitleBlock.Definition.Sketch.TextBoxes
    Select oTextBox.Text
        Case "CONTIENE"
            oPromptEntry  =  oTitleBlock.GetResultText(oTextBox)
 End Select
    Next
Next
xlsxPath = "C:\Users\castellanos.andres\Desktop\Mass Properties.xlsx"
GoExcel.CellValue(xlsxPath, "Hoja1", "A2:A25")=oPromptEntry
GoExcel.Save
But not to do the loop to get the value of all the sheets
Message 5 of 13
So these are not I-properties, but text fields in the drawing, correct?
Please let me know if I understood this correctly, than we can proceed...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 13
 yes, that's right
Message 7 of 13
Ok that is clear than.
I will prepare something and come back to it....
Regards
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 13
chandra.shekar.g
Autodesk Support
Autodesk Support
@andrescastellanosint,
Hoping that below iLogic code may be helpful.
Dim oPromptEntry
Dim oALLSheet
Dim oList As New ArrayList
	oSheet.Activate
	oTitleBlock = oSheet.TitleBlock
        Case "CONTIENE"
            Call oList.Add(oTitleBlock.GetResultText(oTextBox))
 		End Select
    Next
Next
GoExcel.CellValue(xlsxPath, "Hoja1", "A2","A25")=oList
GoExcel.Save
GoExcel.Close
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 9 of 13
Friend thanks for your help, but does not save me any data on the spreadsheet
Message 10 of 13
chandra.shekar.g
Autodesk Support
Autodesk Support
@andrescastellanosint ,
Is it possible to provide drawing document to test ? please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 11 of 13
This is the problem, the drawings are of type cofindencial.
My code works, will only need to create a loop where I save the result into a variable. I have not succeeded.
In the following pictures you can see how the code works, I need is to create a single text message that contains the three data of the pictures.
if you could help me?
Message 12 of 13
chandra.shekar.g
Autodesk Support
Autodesk Support
Hope below iLogic code helps.
Dim oPromptEntry As String
Dim oALLSheet
i = 1
  i = i+1
        Case "CONTIENE"
            oPromptEntry  =  oPromptEntry & oTextBox.GetResultText(oTextBox)
 End Select
    Next
Next
GoExcel.Save
GoExcel.Close
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 13 of 13
Thank you friend is just what I needed
