API export DXF always mirrored
TA.Fehr
TA.Fehr
Is there a way to mirror the DXF created via the oDataIO.WriteDataToFile(sOut, DXFSource) process?
I'm able to automate my dxf exports, but any time there is text, the letters are always reversed.
Has anyone run into this issue?
bradeneuropeArthur
To my understanding the text is also mirrored.
What do you exactly need?
It is not fully clear to me I assume!
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
TA.Fehr
We routinely send dxf's off to a laser engraving facility. So each time we have to ensure that the part is mirrored so that any text is correctly created. This is done by opening AutoCad and mirroring the dxf.
I was hoping for an option to mirror the part before or after the automated dxf is created to avoid this manual step.
It would also do the same thing if I were able to select the opposite face that the text is on for dxf export so that it would un-mirror during creation, but I can't tell how the faces are picked in the initial command.
