Multivalue parameter arrayList throwing error when assigning an array
drouthierXAHY9
drouthierXAHY9
Hi there!
I'm getting an  "Object reference not set to an instance of an object." error when attempting to assign an array to a multivalue parameter.
The multivalue parameter is "test" and the array I'm attempting to assign to the "test" parameter is the form array.
I've attempted to:
  • simply assign the materialStyle array
  • populate the formArray using the "add" function with the materialStyle array
  • directly assign the materialStyle array TO the formArray
I'm simply not good enough to figure out what I am doing wrong.
Dave
AddReference "System.Linq"
AddReference "System.Xml"
AddReference "System.Xml.Linq"
AddReference "System.Core"
Imports System.Linq
Imports System.Xml.Linq
Imports System.Xml.Schema
Imports System.Xml
Sub Main
	Dim feedXML As XDocument
	Dim xmlDocName As String = "C:\Users\drouthier\Desktop\sheetmetalrules.xml"
	feedXML = XDocument.Load(xmlDocName)
	materialStyle = xmlFeedFilter(feedXML, "MaterialStyle")
	Dim formArray As New ArrayList()
	formArray.clear
	For x = 0 To UBound(materialStyle)
	formArray.add (materialStyle(x))
	Next x
	MultiValue.List("test") = formArray
End Sub
Public Function xmlFeedFilter(feedXML As Object, attributeName As String)
	Dim x As Integer
	Dim z As Integer
	Dim objectArray(0) As String
	For Each oElement As XElement In feedXML.Descendants()
		For Each oAttribute As XAttribute In oElement.Attributes()
			If oAttribute.Value = attributeName
				z = 0
				For x = 0 To UBound(objectArray)
					If UBound(objectArray) = 0 Then
					Exit For
					Else
						If objectArray(x) = oElement Then
						z = 1
						Exit For
						End If
					End If
				Next x
				If z = 0 Then
				objectArray(UBound(objectArray)) = oElement
				ReDim Preserve objectArray(UBound(objectArray) + 1)
				End If
			End If
		Next oAttribute
	Next oElement
	BubbleSortAscending(list:= objectArray)
	xmlFeedFilter = objectArray
End Function
Public Sub BubbleSortAscending(list() As Object)
'  Sorts an array using bubble sort algorithm
'  Ascending
'  perform the call from the main as
'  BubbleSort (list:=array)
    Dim First As Long, Last As Long
    Dim i As Long, j As Long
    Dim Temp As Object
    First = LBound(list)
    Last = UBound(list)
    For i = First To Last - 1
        For j = i + 1 To Last
            If list(i) > list(j) Then
                Temp = list(j)
                list(j) = list(i)
                list(i) = Temp
            End If
        Next j
    Next i
End Sub
bradeneuropeArthur
First I see is that:
dim materialStyle as ???????
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
