Mass Properties update with Custom LOD
Message 1 of 8
Dear All
please let me know the code (Ilogic / VBA) for updating mass properties with Custom LOD
thanks in advance
V.Sureshkumar
Replies (7)
Message 2 of 8
Xun.Zhang
@Anonymous,
Some thoughts here.
Go through all unsuppressed components and get the physical properties from each components.
Thanks!
Xun
Message 3 of 8
bradeneuropeArthur
Following code will represent you the Mass of the LOD!
Public Sub massprop()
Dim a As AssemblyDocument
Set a = ThisApplication.ActiveDocument
Dim b As MassProperties ' ComponentDefinition
Set b = a.ComponentDefinition.MassProperties
MsgBox b.Mass
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 4 of 8
Dear Bradeneurope
Thanks for the code, its showing the mass properties value, but i like to update the mass properties with Custom LOD through ilogic.
please let me know
BR
Message 5 of 8
bradeneuropeArthur
ThisApplication.CommandManager.ControlDefinitions.Item("AppUpdateMassPropertiesCmd").Execute
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 8
Dear Bradeneurope
Thanks for the update, the below code is working in Master LOD which i am already using, but its not working in Custom LOD, please see the attached snap shot
BR
V.Sureshkumar
Message 7 of 8
bradeneuropeArthur
Can you put the value in the iproperty mass?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 8
llorden4
Ever find a solution for this you can share?
Autodesk Inventor Certified Professional
