Get Inventor's macros directory location programatically (VBA)
In my macro I use ini file to write and read some settings, so I need to know the (macros) file "Default.ivb" location, which is set in "Application Options" > "File" > "Default VBA project", because in this directory I want to save my ini file.
How can I get directory path where is placed "Default.ivb" file by using VBA?
Best regards,
Marek
pball
ThisApplication.FileOptions.DefaultVBAProjectFileFullFilename
This returns the full file name of the VBA script file. You'll have to strip the file name to get the folder.
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
 Thanks for reply! This is a ready function that I wrote:
Function GetMacrosDirectory() As String 'returns Inventor's "Macros" directory: C:\Users\Public\Documents\Autodesk\Inventor 2018\Macros\
  Dim IvbFilePath As String
  IvbFilePath = ThisApplication.FileOptions.DefaultVBAProjectFileFullFilename 'returns: C:\Users\Public\Documents\Autodesk\Inventor 2018\Macros\Default.ivb
  GetMacrosDirectory = Left(IvbFilePath, InStrRev(IvbFilePath, "\"))   'get the directory path for the "Default.ivb" file
End Function
Best regards. Smiley Happy
Marek
