Marshal.GetActiveObject fails with InventorServer Object. Help!
KKizildemir
KKizildemir
I'am trying to write some code on VS .NET Framework 4.6.1 and to generate a .dll file for my Inventor model that works on C360. So I can not use 'Inventor.Application' object. That's OK.
When I use 'Inventor.InventorServer' object, I can't set that object reference to the intance of my object. I think 'Marshal.GetActiveObject' does not work in this case. So what is the solution?
This is the error message: Object reference not set to an instance of an object.
This is related part of my code:
        Dim oThisServer As Inventor.InventorServer = Nothing
        Try
            oThisServer = Marshal.GetActiveObject("Inventor.InventorServer")
        Catch ex As Exception
            Exit Sub
        End Try
Thanks!
Signature
website
emailskypelinkedinyoutubeemail
bradeneuropeArthur
Is inventor server already running.
Otherwise use createobject.....
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
KKizildemir
Hi Arthur,
Sorry, I didn't get you. Maybe you would like to do your solution clearer.
Thanks anyway.
Signature
website
FRFR1426
I think that Inventor Server can only be used in the context of a job.
GetActiveObject() can not get an instance, it will always returns null.
Inventor Server is started from C:\Program Files\Autodesk\Vault Client 20xx\Explorer\Inventor Server\Bin\VaultInventorServer.exe and then there is a specific process to connect to the running instance which can not be used by an external developer (only Autodesk can use this).
Maxence DELANNOY
Manager
Add-ins development for Autodesk software products
http://wiip.fr
bradeneuropeArthur
That is correct.
You can only use it with a Vault JobProcessor Job!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
