iLogic - Need to run CenterText twice to Center Dimensions
I am having an interesting issue when it comes to automating my Center Dimension Texts on my drawings. Right now I am trying to incorporate this line of code into my iLogic rules:
   Dim oDrawDoc As DrawingDocument
Dim oSheet As Sheet = oDrawDoc.ActiveSheet Dim oDrawingDim As DrawingDimension For Each oDrawingDim In oSheet.DrawingDimensions If TypeOf oDrawingDim Is LinearGeneralDimension Or _ TypeOf oDrawingDim Is AngularGeneralDimension Then Call oDrawingDim.CenterText End If Next
Here is a screenshot of what it looks like after I have run the rule.
I do not get any errors with this, but it just doesn't exactly center it, I can tell it semi works, because I have moved dimensions crazily and run the rule and it pushes it to this location. The weird thing is that we have a plug-in that does this using this code:
            Dim oDoc As Inventor.DrawingDocument = Nothing
            oDoc = g_inventorApplication.ActiveDocument
            Dim oDrawingView As Inventor.DrawingView = Nothing
            Dim oSheet As Inventor.Sheet
            oSheet = oDoc.ActiveSheet
                If TypeOf oDrawingDim Is LinearGeneralDimension Or TypeOf oDrawingDim Is AngularGeneralDimension Then
            Next
Now when I click this button once, it does nothing. However, if I click it TWICE it works:
It is kind of peculiar why I have to run this button twice to get it to work. But, I thought maybe if I just placed the code twice in the iLogic rule, maybe it would simulate the same thing. It did not end up working that way. Does anyone have any suggestions? Or maybe there is another way to code this same function that I can try.
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Can you please provide reproducible steps and Inventor files to investigate? please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
bradeneuropeArthur
I have seen this as normal behavior since inventor 2012.
So I think this is a smaller inventor API bug.
solution:
                    	Call oDrawingDim.CenterText ' 1x
			Call oDrawingDim.CenterText ' 2x
            Next
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
rayessle
I was having the same problem. See this post here
https://forums.autodesk.com/t5/inventor-customization/why-does-this-rule-only-work-the-second-time-y...
I think it has to do with the fact that inventor has not updated the document prior to you trying to centre the text so it doesn't know the dimensions are off centre. when you run the rule the first time it updates the document so the second time it knows the dimensions are off centre.
Thanks for the response. This ultimately is what I did to get it to work.
For whatever reason it still doesn't work without the two executes, but it doesn't work at all if this code runs before the update. Here is what I needed to adjust:
    oDrawDoc.Update
    Next
filippo.costantin3HZMT
I have similar problem with manage dimension with ilogic.
I use a rule like yours, but if I have the configuration o drawing like:iD1.PNG
When I run the rules, the dimensions are overlapping.
How can resolve it?
insomnix
I had to have two update's, one placed between the two center text lines, for it to work properly in my code. For anyone else who is still having issues after trying the above code:
   oDrawDoc.Update
            oDrawDoc.Update
    Next
 Thanks to those responding on this thread, you pointed me in the right direction.
