Save sheet as STEP with ilogic
S_May
Mentor Mentor
S_May
Hello everybody,
it is possible to ilogic storing the flat sheet as STEP?
clutsa
It doesn't look like it will directly but I bet we can saveas a .sat file and then open that and export the new .ipt all with iLogic. I'll work on some code at break tomorrow.
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
chandra.shekar.g
Autodesk Support
Autodesk Support
@S_May,
Unfortunately, Inventor API does not support to export to step file directly. But, try to export to .sat file and open in Inventor file. Finally, .sat file can be exported to required .step file.
Please log this wish list at idea station using below link.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
acanx21
I have this code for exporting out step files with no dialog windows through ilogic, but I've tried it on a couple of sheet metal flat patterns and I think it just exports out the folded part.
Stepfilename = ThisDoc.PathAndFileName(False)
CurrentFile = Stepfilename & ".stp"
' Get the STEP translator Add-In.
Dim oSTEPTranslator As TranslatorAddIn
oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById _
("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
Dim oContext As TranslationContext
oContext = ThisApplication.TransientObjects.CreateTranslationContext
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
If oSTEPTranslator.HasSaveCopyAsOptions(ThisApplication.ActiveDocument _
, oContext, oOptions) Then
oOptions.Value("ApplicationProtocolType") = 3
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
Dim oData As DataMedium
oData = ThisApplication.TransientObjects.CreateDataMedium
' Set export name of STEP file
oData.FileName = CurrentFile
oSTEPTranslator.SaveCopyAs(ThisApplication.ActiveDocument, oContext _
, oOptions, oData)
I also have this code for unfolding a sheet metal part:
Dim oDoc As PartDocument
oDoc = ThisDoc.Document
check = 0
' Make sure the document is a sheet metal document.
If oDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
MsgBox("A sheet metal document must be open.")
Exit Sub
'flatten sheet metal
Dim oSheetMetalCompDef As SheetMetalComponentDefinition
oSheetMetalCompDef = oDoc.ComponentDefinition
If Not oSheetMetalCompDef.HasFlatPattern Then
Try
oSheetMetalCompDef.Unfold()
Catch
MsgBox("This part does not have a flat pattern.")
End Try
oDoc.Update2(True)
I tried combining them to see if that would export out the flat pattern but no luck so far. Maybe if you play around with these codes though, you'll be able to.
clutsa
@S_May sorry that "tomorrow" came so late
@acanx21 thanks for the Step file code that saved me a ton of time
I wasn't able to  use the true "flat pattern" but I did manage to flatten the part, save the .STEP, and unfold the part again (based off a suggestion from @dean.morrison at https://forums.autodesk.com/t5/inventor-customization/flat-pattern-export-to-new-part/m-p/7681298#M7...)...
Dim app As Inventor.Application =  ThisApplication
Dim oDoc As PartDocument = ThisDoc.Document
	Exit Sub
Dim oTransMgr As TransactionManager = app.TransactionManager
Dim oTrans As Transaction = oTransMgr.StartTransaction(oDoc, "MakePartFlat") 'will be used to undo to this point
Dim CompDef As SheetMetalComponentDefinition
Dim oFeatures As SheetMetalFeatures = CompDef.Features
Dim BaseFace As Face
'BaseFace = app.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select the stationary face.")
BaseFace = oFeatures.ContourFlangeFeatures(1).Faces(2) 'this line may not work all the time, the line above can be used instead if this gives you trouble
oFeatures.UnfoldFeatures.Add(BaseFace)
'CreateSTEP
, oOptions, oData)
oTrans.End 'end undo point
Dim undoCmd As ControlDefinition = app.CommandManager.ControlDefinitions("AppUndoCmd")
undoCmd.Execute 'undo unfold
