Referenced files by the assembly
martinhoos
martinhoos
Hello all,
i found a code that gives all referenced files by the assembly back. Even files by sub-assemblies.
'- - - - - - - - - - - - -Component Drawings - - - - - - - - - - - -'look at the files referenced by the assembly
	Dim oRefDoc As Document
	Dim fileName As String
	' For Each oRefDoc In oRefDocs = oAsmDoc.AllReferencedDocuments
	For Each oRefDoc In oAsmDoc.AllReferencedDocuments
		oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName) - 4)
		For Each fileName In System.IO.Directory.GetFiles(oPath1, "*.idw",System.IO.SearchOption.AllDirectories)
			If fileName.EndsWith(oFileName + ".idw") = True Then
				Dim oDrawDoc As DrawingDocument
				oDrawDoc = ThisApplication.Documents.Open(fileName, True)
				On Error Resume Next
I like to have a modification, so that the code only gives referenced files from the assembly NOT from the sub-assemblies. Is that possible?
Need your help.
Thanks in advance
Regards from Germany...
Martin
LukeDavenport
Use ReferencedDocuments instead of AllReferencedDocuments.
Luke
martinhoos
Hi Luke,
thank you very much for your reply. This works well!
Regards
Martin
