Maintaining Filename, Part Numbers, etc - automatically?
aaron
Message 1 of 11
aaron
I've been teaching myself how to use Inventor for a number of months now.
In this effort, I'm not using iParts, though I'm sure they could be useful. I don't understand them perfectly, aside from standardized "configurations" - if we could call them.
I use a parametric approach using a master sketch to automatically model several parts that make up an assembly.
My challenge is then naming all these files (it's a tedious endeavor through Design Assistant).
I'm trying to input a [ProjectNumber] that can then populate the [Filename] and [PartNumber] of all these files...
I thought this could be possible through the iPart/iAuthor Dialog box, but I have been unable to make one cell equal another. I know some people are able to import Excel documents (in which they perform that operation).
Say I have a few columns:
Member (filename)
Part Number
Project Number
Is it possible to have Part Number and Member (filename) read Project Number?
e.g.
Member--------------Part Number-----------Width
MEMBER-20-12     PN-20-12                  20-12
Replies (10)
Message 2 of 11
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @aaron,
The following blog links would be helpful.
http://adndevblog.typepad.com/manufacturing/2013/02/manipulate-rows-and-columns-of-ipart-1.html
http://adndevblog.typepad.com/manufacturing/2016/01/customize-iassembly-ipart-member-creation.html
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 11
aaron
Hello @chandra.shekar.g
Thank you for the response, and it is very informative, but it doesn't quite achieve my goal. I am working on custom solutions of a product, where the geometry changes (e.g. Length, Width, Height, Gap Spacing, Width and Number of beams, etc), but the product does not.
A good example, is a Window - A window may be 4x4 with 4 glass panes, or 6x4 with 6 panes.
Master file: "100-2001 - Window Layout" - Contains data for all the other parts.
File 1: "100-2001 - Glass Pane"
File 2: "100-2001 - Frame"
File n: "100-2001 - xx"
It would be fantastic if I could open the Master file and type "100-2001" in the Project field, and automatically populate all the names and parameters for the other components, and save each Part with the appropriate file name (e.g. "100-2001 - Frame")
Thanks in advance..
Message 4 of 11
bradeneuropeArthur
If you use vb.net you can use the metadataevent for this.
If you need assistance please let me know.
While in I logic this is very hard to do without understanding the API
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 5 of 11
Frederick_Law
Thanks in advance..
You can edit iPart in Excel and use excel function to combine cell values.
Message 6 of 11
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @aaron,
Custom application can be developed through inventor Addin. For more details about Inventor Addin, refer the following Inventor API online help link.
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-52422162-1784-4E8F-B495-CDB7BE9987AB
We can assist in giving information about Inventor API. Please let me know if you stuck up anywhere.
Hoping that video would help your requirement.
https://www.youtube.com/watch?v=OHolDSVKU8M
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 7 of 11
aaron
@Frederick_Law
Thanks, I do know how to do that, but I have been unable to find a way to pass strings between different Part or Assembly files, and have the filename reflect it. That would resolve my issue.
Message 8 of 11
aaron
@chandra.shekar.g
Thanks, That's very interesting. I think developing a custom Addin using the API is beyond my current abilities.
Ideally, as I wrote above, I have been unable to find a way to pass strings between different Part or Assembly files, and have the filename reflect it.
Message 9 of 11
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @aaron,
Hoping that below blog link would help to rename part or assembly file.
http://adndevblog.typepad.com/manufacturing/2015/12/rename-file-referenced-from-assembly.html
Here, ComponentOccurence in Assembly could be either Part or sub Assembly file.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 10 of 11
aaron
I can semi-follow the code on the page having taught myself a little bit of VBA over the past couple months (for Excel) knowing a little bit of programming in other languages. Ultimately, I'm a mechanical engineer with other specializations - and I don't think I can manipulate my files easily using your methods... (They require a steeper learning curve).
Message 11 of 11
chandra.shekar.g
Autodesk Support
Autodesk Support
@aaron,
To start, Parametric modelling is a best approach. There are many videos are available in YouTube channel.
https://www.youtube.com/watch?v=RiVhFNuX1r8
Please let us know which programming language is comfortable?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
