Inventor 2018 Manually Add Diameter Symbol To Alternate Dimension
chris54
chris54
I'm using alternate dimensions on this print.  I had to manually insert a dia symbol in front of the main dimension.  How can I also get one in the alternate dimension???
Inventor 2018
Thanks!
Chris Breidenbaugh
kelly.young has edited your subject line for clarity: ALTERNATE DIMENSION
kelly.young
Autodesk Support
Autodesk Support
Hello @chris54 as far as I know out of the box getting a symbol in-between the primary and alternate is not possible.
There might be a snippet of iLogic to force one between.
Please select the Accept as Solution button if a post solves your issue or answers your question.
