Changing dimension defaults
chris54
chris54
By default Inventor puts an "R" in front of any radius dimension.
Is there a setting where I can change that to SR (spherical radius)?
Inventor 2018
Thanks!
Chris Breidenbaugh
kelly.young
Autodesk Support
Autodesk Support
@chris54 as I'm sure you're aware you can edit the dimension and simply add the S before the dimension.
To automate this out of the box will not work as you cannot get to the Radius command placement options from the Styles Editor.
You can however add this to a few other areas shown here:
There might be iLogic to amend the Radius call out and add the S to the beginning.
Please select the Accept as Solution button if a post solves your issue or answers your question.
