Lines,curves visibility in sketch
How to customize inventor so I can see lines in sketch when drawing lines an curves in opposite(rear)plane,f.e inner groove in cylinder.I cant see what I am doing exept I use section throug working plane.
dgreatice
can you explain by picture or video?
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Unfortunately not possible now,but f.e You make cylinder from top plane center extrude both sides.Then You want to make a hole from f.e. right plane from center point.When you start sketch and start circle from center You don't see sketch edge of the circle.It can be solved from section command,but it is time consumable and in some complex shapes sometimes problematic.
