Valvw Publishing
Valvw Publishing
Valvw Publishing
I am wondering if anyone can help me,  I am trying to Author a Valve in Inventor 18, when I add the command to the ribbon it is greyed out and not available, can you suggest a solution, thanks
T&P + Greyed OutT&P + Greyed Out
dgreatice
Tube n Pipe Authoring can be access in Part, not in assembly document
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
