Detail view issue
Detail view issue
cyndel.pigeon
Detail view issue
cyndel.pigeon
Hi!
When I'm doing a detail view...my detail view show the whole part instead of only show what I have selected for the detail view...
I did some tests and it looks like the problem is about the part since it works with other I tried.
Thank you!
philip1009
Could you post some pictures, video, or attach the files here so we can better understand the error?
cyndel.pigeon
The detail view doesn't look like a detail view since the view is the same as the base view...
philip1009
Yeah that's certainly a glitch, it looks like all it did was make a larger view, but didn't crop it to match the selection.  I'll notify the moderator to move this post over to the main forum since this is a general Inventor issue.
dgreatice
can you share that code too?
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
