SheetMetal.FlatExtents in a loop
Could someone help me modify the below code to pull the flat length & width extents from each sheet metal part in my For loop ? It returns 0 for both at the moment.
For Each oRow As BOMRow In oBOMRows
		oRowCompDef = oRow.ComponentDefinitions.Item(1)
		If oRowCompDef.Document.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
			Dim oCD As SheetMetalComponentDefinition = oRowCompDef
			FlatLength = SheetMetal.FlatExtentsLength
			FlatWidth = SheetMetal.FlatExtentsWidth
			MsgBox(oRowCompDef.Document.DisplayName & vbLf & "Length = " & FlatLength & vbLf & "Width = " & FlatWidth)
Next
marcin_otreba
try:
            FlatLength = ocd.FlatPattern.Length
            FlatWidth = ocd.FlatPattern.Width
            MsgBox (oRowCompDef.Document.DisplayName & vbLf & "Length = " & FlatLength & vbLf & "Width = " & FlatWidth)
Next
YuhanZhang
Try below code:
            If oCD.HasFlatPattern Then
                Dim oFlatPattern As FlatPattern
                oFlatPattern = oCD.FlatPattern
                FlatLength = oFlatPattern.Length
                FlatWidth = oFlatPattern.Width
Next
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
