Message 1 of 13
Keyway suppression under 6mm
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm making a coupling file to speed things up on my end with 3d modeling. So far I have gotten my bores to match DIN 6885 when they go above 6mm and have the correct keyways, below 6mm i have made a snippet that doesn't allow keyways to be generated. I have also gotten a form where I can select true or false on a keyway, but having that rule will allow keyways at the last size to be visible and selectable for the bores below 6mm, I'm not sure if I have to make another rule to run to disable the key rule from running when selecting under 6mm or if there is a way to do it directly in the key suppression rule.
I do have the Ascent student guide for iLogic 2018 and I got this far with it, but I'm not sure what I'm asking for is in the book.
